Thread: Color balancing Scarlet-X and Canon C300
Page 1 of 8 12345 ... LastLast
Results 1 to 10 of 73
  1. #1 Color balancing Scarlet-X and Canon C300
    Senior Member Sanjin Jukic's Avatar
    Vienna, Austria
    This probably going to be a long tread.
    Main goal of the tread is bringing the Scarlet-X extremely close to a standard look of C300.
    It's the first test of color balancing between those two cameras and more other test examples will come soon after this one.
    So I just started with a very simple test to try out matching and balancing color between those two cameras using PS5.
    Next tests will include grades in DaVinci Resolve, After Effects, FCP7, FCPX, etc.
    Both cameras have installed the latest firmware updates, SCARLET Build v3.0.0 Firmware, .
    Shot on Scarlet-X with Leica-R Summilux 50mm f/1.4 @ f/5.6, WB: 5000K, EI 800 (ISO), no filters, matching CC RCX + PS5.
    Shot on Canon C300 with Leica-R Summilux 50mm f/1.4 @ f/5.6, WB: 5000K, EI 800 (ISO), no filters, no any CC.
    Shot on Scarlet-X with Leica-R Varion Elmarit 28-90mm f/2.8-4 @ 35mm, f/5.6, WB: 3400K, EI 320 (ISO), Filters: 85N9 Tiffen, Circ-Pola Formatt, matching CC RCX + PS5.
    Shot on Canon C300 with Leica-R Vario Elmarit 21-35mm f/3.5-4 @ 35mm, f/5.6, WB: K5000, EI 320 (ISO), Filters: ND4 in camera rotary ND filter, Circ-Pola Tiffen, no any CC.
    BTS: Color balancing test between Scarlet-X and Canon C300.
    The next test is coming soon.
    Stay tuned.
    "There is no point in having sharp images when you've fuzzy ideas."
    Jean-Luc Godard.
    Dynamic range is, after all, the measurement between well saturation (photosite blowout) and noise floor.
    Thom Hogan
    500px >>>
    Twitter >>>
    Facebook >>>
    Vimeo >>>
    Senior Member luigivaltulini's Avatar
    Oct 2009
    Switzerland- LUGANO
    Thanks Sanjin,
    just waiting for this test, thanks.
    I look forward to the next.
    luigi
    TELEVISION BROADCAST SWITZERLAND
    www.rsi.ch
    Color Correction DAVINCI Resolve/Digital Workflow/Red Camera Rental
    EPIC #599 and #668
    SITE
    www.cine5k.ch
    Hi Sanjin!
    Thanks for sharing, but I have to ask: Why set the scarlet to 3400K and put an 85 filter? Why not just go with 5600K in câmera since it is what is closest to it`s native color temperature? And why not do the same with the C300?
    Also, the two day scenes exposures don`t seen to match, the Scarlet`s one look a little under compared to the C300.
    Do you Own both cameras? Any thoughts on how they compare to each other?
    Best Regards!
    Vienna, Austria
    Quote Originally Posted by luigivaltulini View Post
    Thanks Sanjin,
    luigi
    Thanks Luigi,
    I just started and hopefully everything will be okay in the end with those matching results.
    Jean-Luc Godard.
    Thom Hogan
    500px >>>
    Twitter >>>
    Facebook >>>
    Vimeo >>>
    Vienna, Austria
    Quote Originally Posted by Rodrigo Prata View Post
    Hi Sanjin!
    Best Regards!
    Rodrigo,
    yes I owe both cameras.
    And naturally have a learning curve with both of them at the beginning.
    Also by my own experience with RED ONE M and MX after using ND1.2 you get a serious troubles with IR pollution and color shift even if you use a special IRND filter aka hot mirror from any brand.
    At the beginning of this test I'll try with 85N9±CircPola and than later with ND1.2+IR±CircPola.
    More or less they are two very different cameras and can perfectly compensate to each other.
    It looks very similar if you would be able to shoot with two different film stocks and then your output format is mainly 2K or HD.
    Jean-Luc Godard.
    Thom Hogan
    500px >>>
    Twitter >>>
    Facebook >>>
    Vimeo >>>
    Senior Member Alvise Tedesco's Avatar
    Milan Italy
    Hi Sanjin.
    Interested in what you'll do here, but what's the point of showing small jpegs?
    Btw, I'm so loving the Vario 28-90 (and the Elmarit 19, and the Summicron 35, and the Summicron 50)
    Vienna, Austria
    Quote Originally Posted by Alvise Tedesco View Post
    Hi Sanjin.
    The next examples will offer to get a full HD images or even a footage to download.
    Jean-Luc Godard.
    Thom Hogan
    500px >>>
    Twitter >>>
    Facebook >>>
    Vimeo >>>
    Sep 2009
    Belgium
    Thanks Sanjin for the test ! That could be very interresting.
    Digital FrameworX
    Franck De Togni - Mo-Pho-grapher
    Dec 2010
    Toronto
    Quote Originally Posted by Sanjin Jukic View Post
    that would be awesome!
    Senior Member Les Dittert's Avatar
    Sep 2011
    Have you tried a 3d lut to get the color to match ?
    Here is Red colored to match Canon:
    -Les Dittert
