Click here to go to the first RED TEAM post in this thread.   Thread: SALT II results... (Part 1,2,3,4 Bokeh, Breathing & Flare and Part 5: Impressions)
Page 2 of 17 FirstFirst 12345612 ... LastLast
Results 11 to 20 of 170
  1. #11
    Quote Originally Posted by Tom Gleeson View Post
    What aperture were the lenses set to fr the measurements? Thanks for the test.
    For projection, wide open, pretty much all lenses look great two stops down, for cinema use we need to know what a lens looks like at it's worst, what it's breaking point is.
    The other tests to be posted later were done at either 2.8 or wide open and 2.8.
    "All art is deception."
    My DP reel...
    http://www.evingrantdp.com
    http://www.YouTube.com/evingrant
    360º Cinematography and camera rigs...
    http://www.360dop.com
    Senior Member Jeffrey T. Morgan's Avatar
    Oct 2007
    Michigan
    Wow! This is a great present!
    Jeffrey T. Morgan
    Producer • Director • Cinematographer (Local 600) • Editor
    www.PrometheusMotionPictures.com . . . Twitter: (at) JeffreyTMorgan
    SCARLET-X #1633 "The Dark Knight", Now booking Michigan and Worldwide
    Canon and PL Mount, 5" Touch LCD, RedRock FF and Mattebox, Cartoni Delta Head, Contax Zeiss lenses and much more
    Jan 2007
    Thank you Evin, and to all who participated and made the test possible.
    Hope you are also having some fun with that RED electronic Nikon mount.
    Writer - Director
    Crowing Lakes.com
    Mar 2011
    Toronto, ON Canada
    That chart needs another column - the amount of focus rotation. The Leicas are amazing at 270 degrees making them a very attractive PL alternative.
    ___________________________
    10 frame handles
    Vimeo
    Scarlet #329 "HAL"
    There will be a whole section on Mechanics.
    My DP reel...
    Digital FX Greg M's Avatar
    Can you report the serial numbers on the Leicas?
    digitalfx.tv
    The RGBlog- Ramblings about Cameras, VFX, etc.
    Twitter
    Red One #83
    Epic-M #98 and #240
    Epic-X #83 and #116
    They are Matt Uhry's set. I'll leave that up to him.
    My DP reel...
    Quote Originally Posted by Greg M View Post
    It's these lenses:
    Basically all 3 cam non ROM all over 28 xxxxxxxx except the 19mm is a V2 Rom.
    We did not include the 60mm in the test, but it looked good on the projector.
    Matt Uhry
    www.mattuhry.com
    Dec 2010
    Saw tests by K.R. And others between Zeiss 21mm and Nikon 14-24 where Zeiss completely beat Nikon zoom. But not according to you..Zeiss is so much sharper especially wide open. Zeiss Also gives you more organic look.
    If you mean Ken Rockwell, well, then you need to consider your source. Organic looks is an opinion, I felt all the lenses in the test produced a look that could be described as organic, depending upon your criteria. Overall the lenses were more similar than not.
    The Zeiss 21mm did quite well overall, but at least on the projector it was not sharper than the 14-24 Nikkor, although on an Epic you probably couldn't tell one from the other on sharpness alone.
    My DP reel...
