Thread: Rolling shutter different for Scarlet?
Page 4 of 8 FirstFirst 12345678 LastLast
Results 31 to 40 of 78
  1. #31
    Senior Member Will Keir's Avatar
    Sep 2009
    California
    Yeah, not much difference in those shots.
    Quote Originally Posted by Glen Powell View Post
    If there is a difference then it's negligible based on the two frame grabs...
    Will Keir
    Creative Director ~ Jumping Rock Pictures
    Epic X #2482 / R1 #3033
    "Why I choose film?
    The friendships, the adventure, the art."
    So I did a rough timing of the Scarlet at 23.976 4KHD and was very disappointed to find a read time of about 14ms or about 1/72 second.
    This is no better than the original RED One - maybe a bit worse.
    If anyone has gotten a different result or anyone from RED knows the exact spec, please let us know. I would love to be wrong here. But I am quite confident about my methodology.
    Nov 2009
    Quote Originally Posted by Eric Pascarelli View Post
    How did you measure?
    PossiblyUli Plank, who has both an Epic and a Scarlet, can run the test?
    14ms is a LOT of delay. I was under the impression it would be in the 5ms range?
    I measured it by doing a smooth, fast, long lens pan across a vertiical line and examining two successive frames in Photoshop. Used a tight shutter (1/1000) to reduce blur and made sure the vertical line intersected top and bottom of frame.
    For the math, first, I found the pan speed in pixels per frame (around 1200 in this case) by comparing the bottom of the skewed vertical in the two succesive frames.
    Then I found the amount of skew in pixels by looking at the horizontal offset (top to bottom) of the skewed vertical in each frame (around 400 in this case, and the same in both frames, proving constant speed). The ratio of the two numbers (400/1200=.3333) is the ratio of read-reset time to frame cycle time. Since frame cycle time is 1/24 of a second, read-reset time is 1/72 second.
    Nov 2009
    Hmmm. I'm going to have to get my head around the math and why you chose to calculate it that way!!!
    I did find an un-comfirmed figure of read/reset time of 5ms for the Epic - and that the read-reset time is closely tied to the sensor click-speed. If they've slowed down the sensor clock speed on the Scarlet, it going to be slower.
    It's annoying to think that the Scarlet could be slower, as on 2/15 I got an authoritative answer in an email from RED saying that
    "I have confirmed with our engineers that the read/reset rate for both EPIC and Scarlet will be the same."
    Now, I'm not sure what to think. If they don't publish the figures, I guess there must be a reason not to?
    My understanding is that the ARRI has much less of a lag, so I guess there's competition in that regard. But, we should be provided with the facts in order to make an informed decision.
    This thread also outlines another interesting way to measure rolling shutter:
    http://www.scarletuser.com/showpost....30&postcount=3
    And I wonder if the Foundry plug-in's 15 day trial could be used to calculate the offset? (btw - that plug-in, from the reviews I've read, sometimes works and sometimes if there's too much motion, creates a real mess).
    Senior Member Matthew Scott's Avatar
    Nov 2008
    Melbourne, Australia
    Set up both cams, 100mm lens or longer, shoot a van driving past at exactlyish the same speed. (above 100kph would work best).
    The math is pretty straightforward, so maybe I haven't explained it well. Basically I'm redefining time in terms of pixels (which you can do with a constant pan speed) and then counting how many pixels, as a unit of time, it takes to scan from top to bottom of frame. Each horizontal pixel accounts for 0.00003472 seconds of panning (1/(24*1200). Since it takes 400 pixels to get from top to bottom of frame (as evidenced by a 400 pixel skew from top to bottom) and each pixel is 0.00003472 seconds, then it takes 0.00003472 x 400 = .0138 seconds to scan from top to bottom. Approximately.
    Very disappointing number.
    I've heard Alexa is 7ms but haven't had a chance to test it.
    I love the Foundry and all of their motion estimation plugins. But they all fall apart in extreme cases and can't be relied on to always fix a slow shutter.
    Braunschweig, Germany
    Currently, our Scarlet and Epic are not available for a test.
    Regards,
    Uli
    My Red is called Vertov after a Russian avantgarde filmmaker, a pioneer in modern cinematography, a true revolutionary who later suffered under Stalin's bureaucracy.
    Apr 2008
    Quote Originally Posted by Uli Plank View Post
    Uli… maybe you can ask Graeme…
    I seem to remember him categorically saying that there was no difference in rolling shutter between Epic and Scarlet as the read out times were supposed to be the same.
    Perhaps he meant no significant difference?
    I don’t know??
    Eric
    Scarlet-X00750 "Reggie" and Scarlet-X00683 "Larry"
    Nov 2009
    Quote Originally Posted by Eric Lange View Post
    I don’t know??
    Eric
    I can't find a comment from Graeme on this, but someone said he said that here:
    http://www.reduser.net/forum/showthr...l=1#post907974
    If you ever get into motion tracking (for the money we are paying, hopefully you will not want to limit yourself to all jobs except those that need motion tracking), here's an explanation of rolling shutter on CMOS cameras affecting SynthEyes (used in many small movies like Avatar, Mission Impossible: Ghost Protocol, etc.)
    http://www.ssontech.com/phpBB2/viewtopic.php?t=478
    BTW - Motion Tracking is not just for special effects shots. 'The Girl with the Dragon Tattoo' used SynthEyes and After Effects (all shot in 4K R3D files on Epic and RED MX) to stabilize the footage. So, this will affect a 'normal' workflow if Scarlet has more rolling shutter than the Epic. SynthEyes is very reasonably priced.
    1/72 second is a lot of rolling shutter.
    I hope the test used to arrive at that is somehow flawed, but ... the math does seem straightforward and logical.
