Click here to go to the first RED TEAM post in this thread.   Thread: Hotkey to switch between orginal picture and modified?
Results 1 to 6 of 6
  1. #1 Hotkey to switch between orginal picture and modified?
    Senior Member Joel Arvidsson's Avatar
    Nov 2008
    Sweden
    Is there any hotkey that switch back and forth original picture as shot in camera and modified?
    Scarlet #00549 Elmer
    not really a hotkey but as a workaround you can apply the look preset called 'Meta', it will restore everything to in-camera settings, then undo/redo will work as a hotkey to compare before/after...
    In camera it you would map VIEW RAW to one of your buttons.
    David
    "A revolution is not a bed of roses.
    A revolution is a struggle between the future and the past." – Fidel Castro
  4.   This is the last RED TEAM post in this thread.   #4
    Although not a hotkey, the M button on the top of the Viewer (next to the 1,2,3 buttons) will show the "as shot" look while pressed, then return to the modified look when released.
    Nov 2008
    Sweden
    Thanks Grant! Where do I put in wishes to get a hotkey for this? I think more than me wold like this on a hotkey.
    Jan 2010
    +1 for the hotkey option
