Quote Originally Posted by TheBied View Post
This feature is slated for a future release.
The compression ratio spinner will select a "desired" compression ratio that the camera will always attempt to meet. If based on settings (resolution, fps, maximum media data-rate, or capture mode) the target is not achievable, the next best setting will be used and will be highlighted in yellow.
Perfect!
