Thread: These Cables Work. (And why)
Page 4 of 4 FirstFirst 1234
Results 31 to 35 of 35
  1. #31
    Senior Member Elsie N's Avatar
    Oct 2009
    Reviving this because I can't find confirmation; will the HOSA XVS 102F/101F pass phantom power through?
    Also, how is the unplug-while-phantom-power-is-on-ruins-your-sound/mic issue on Scarlet/Epic? Someone on the first page mentioned the R1 did some very bad things if you did this.
    Bump this.
    One camera is a shoot... two or more is a production.
    L.C. (Elsie) N., omniographer.com, dba nelloProductions, LLC (soon)...looks like a good time to start a business.
    Dec 2007
    Norwich, CT. USA
    Quote Originally Posted by Calle Herdenberg View Post
    First I should say that I know nothing about audio.
    I recently bought a Sennheiser MKE 400 to have a small microphone to help syncing the audio when editing. Yesterday I spent a few hours to get it to work:-) I wasn't successful. That was before I red this thread.
    The Sennheiser has a 3.5mm TRS mini cable. Is it the wrong kind of TRS cable? Do I need an adapter? Or am I just using the wrong settings in the camera?
    We chased down that answer in this thread:
    http://www.reduser.net/forum/showthr...heiser-MKE-400
    First, we started on the connectors - which seemed to be the right ones.
    After some investigation, we found that the wiring on the MKE400 was the issue.
    Sennheiser was considering an adapter cable - turns out the combination is at the mic, not the connector end so that would not work.
    They are thinking...
    In the meantime, the MKE400 will not work - you need to find a mic that not only has a balanced connector, but the correct isolated wiring behind it.
    I know that many at RED HQ curse the mini-XLR's, but how I wish they were on the front of the EPIC and Scarlet cameras...
    Junior Member
    May 2009
    Stockholm/Sweden
    I saw this thread just now.
    They asked that I post this for the time being:
    Due to the unique connector and wiring scheme of the Scarlett camera, the MKE 400 with its standard cable will not operate. We are investigating an adapter cable and will keep users posted on developments. Thank you.
    So I guess getting another mic would be best.
    Get a 3.5mm stereo (female) to 3.5mm mono (male) adapter at Radio Shack...
    Or do you still think an adapter could work?
    Dec 2007
    Norwich, CT. USA
    Adapters are not the solution - this was provided to me by Sennheiser's Technical Director in the US:
    "Upon further analysis, even unbalancing will most likely NOT work, as tip and ring are connected together inside the microphone, thus shorting out the audio input no matter whether is configured balanced or unbalanced ..., "
    I'll be at their US HQ sometime in the next few days - I'll check to see what progress they have made in developing a solution - or, in worst case, report if they have found that there is not one.
    Dec 2010
    Toronto
    I must recant what I said... Apparently it doesn't work with the MKE400. I don't have one to test, but everyone mic I have works with a stereo to mono (with phantom power OFF, obviously.
