Thread: These Cables Work. (And why)
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
  1. #11
    Senior Member James Brundige's Avatar
    Feb 2008
    Snowmass, Colorado
    Quote Originally Posted by D Fuller View Post
    If I'm not working with an audio recordist with a TC recorder, I run all audio through a Sound Devices Mix Pre-D. It provides phantom power, great preamps, meters, mic-level outs and has a nice, small form factor. I use the Hosa XVS cables to connect the Mix Pre-D to the Epic.
    Thanks for this thread, would have saved me hours of headaches.
    Do you have to pad the output of the mix pre?
    Oct 2008
    Gorham, Maine
    Quote Originally Posted by James Brundige View Post
    You're welcome. Your problems were the inspiration for this thread, so at least some good has come of it.
    Sound Devices makes both something called a "MixPre" and something called a "MixPre-D". I have the "MixPre-D". I do not have to pad the output, because its output is switchable between Mic level and Line level. I just switch it to Mic level.
    I have never used the "MixPre" so I can't tell you whether it can put out a Mic level. From other posts I've seen here, I suspect that it may not be able to do that, but I try not to speculate too much on things I really don't know.
    David Fuller
    AirStream Pictures
    RED ONE #172MX
    EPIC-M #1053
    James, I use this to pad the mixpre output:
    http://www.amazon.com/Hosa-ATT-448-F...8288707&sr=8-1
    set at -40dB works well
    Had I seen this sticky first it would have saved me a lot of wasted time... Maybe RED should throw one of the proper cables, with a wiring
    description, in with their Epic/Scarlet packages??? That would cost RED very little and save their customers some headaches.
    Rob Sweeney, DP
    Junior Member
    Nov 2008
    San Diego, CA
    Does anyone know if x's A box is wired this way?
    Micajah Smithson
    Producer/Director
    West Coast Projections, Inc.
    San Diego, CA
    Thanks for the concise info. Much appreciated!
    Ryan Holdridge
    Senior Producer
    Mad Media LLC
    San Diego, CA
    Senior Member Jack Shanahan's Avatar
    Nov 2011
    NYC
    PROBLEM SOLVED: FRESH BATTERIES IN MIC :)
    I have just recieved two of these cables and am trying to use them with a Senheiser shotgun mic. I am getting lots of noise and feeback from the camera...
    Maybe I have the wrong mic? It is an unidentified Senheiser shotgun. It has a AA battery, a little black switch ("BATT. ON") and then an inlayed switch that is red with a line and an angled line next to it. The LED doesnt seem to illumitate when I push the switch up to BATT ON. I am not sure if this mic is needs phantom power or not...maybe that is the problem?
    However when I put the dB above 35-40 I can hear noise/feedback from the fan (which changes pitch as per fan speed), also clicking while recording, which all amount to an unusable signal...
    Any advice out there? How to ID an unmarked Senheiser Mic? How to know if thats the problem?
    EDIT: I tried multiple batteries....
    EDIT 2: When AC power is attached the noise is DEF greater.
    EDIT 3: I think I am using the Sennheiser ME66/K6
    Jack Shanahan
    www.jackshanahan.com
    EPIC-X + Zeiss ZF Duclos Mods
    Senior Member Kwan Khan's Avatar
    Jan 2008
    NYC
    Nice
    Rent 5K for $500/day - NYC (Times Square)
    www.finalfootage.com
    EPIC-X + Rocket, RPP, 18-50, Nikon 17-35, 50, 80-200, A-Mount, MBPro, VF FF, Pancro Budget Kit, Pana 17", JVC 20".
    Green Screen Studio @ Times Square (with Reflecmedia), Kino 8'4/4'4/2'4' Kit, Arri Kit, Lite Panle, EZ-JIB + Varizoom Remote Head, Indie-Dolly kit, Cine-Slider, Glidecam X-10 & 20 with SEGWAY,
    MBP (Retina), MacPro, RAID system (Promise Pegasus), Adobe Production (CS6), FCS2, Resolve 9 with MC Color.
    No. As Stephen says above, there is no phantom power to get. The release notes for every firmware build so far have said:
    +1 on the sound devices. Gorgeous sounding pre amp. For a cheaper run and gun application I believe you can use one of those zoom recorders to pass the audio on to the epic. Use the onboard mics or plug in your own condenser. It provides phantom power.
    May 2010
    Duesseldorf, Germany
    Thanks so much for the great info, D! I had 3 cables made to the HOSA specs you described and they work perfectly on my Scarlet.
