Thread: Dual System Record Instructions for SD 744t and Scarlet/Epic (how to use timecode)
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. #1 Dual System Record Instructions for SD 744t and Scarlet/Epic (how to use timecode)
    Senior Member PatrickFaith's Avatar
    Nov 2011
    Northern California
    These instructions use timecode to sync sound recorded on a 744t to video recorded on a scarlet.
    My exact config:
    RED Sync to bnc cable (the epic/scarlet one ... has 3 bnc's, if you use red one, you need the 2 bnc cable).
    bnc2bnc connector sound device cable "xl-lb2 lemo to BNC i/O cable" ( most film productions do it fancier then this).
    Sound Device 744t.
    sennheiser 416.
    Adobe Premiere.
    Windows 7.
    Reset the sound device 744t to "film" (this put the sound device into a default state, this is almost the same as default but put's mic 1&2 into phantom mode, it only needs to occur once when you get the 744t).On the scarlet, set the timecode to external.(I also am always in QHD mode, 24 fps, 1/24th time ... with the project set a 24 fps, i haven't tested the other modes).Turn off both the 744t and scarlet/epic (i'm not sure this is necessary ... but i'm paranoid on connecting cables with power on). Connect your mic's (i use a Seinheiser 416, by default you get 4 lines recording btw). Connect the sound device cable "xl-lb2 lemo to BNC i/O cable) to the 744t time code lemo connector. Connect a bnc-2-bnc connecter to the sound device cable bnc. Connect a 3 bnc to sync cable (from red, it's a 2 bnc for red one) to the scarlet/epic. Connect the Yellow bnc of the scarlet's sync cable to the bnc-2-bnc connector.
    You should now have your 744t connected to your scarlet. Hook up your mics (with film mode, mic 1& 2 are default phantom btw). Turn on you sound device 744t. Turn on your scarlet/epic. You should notice that the times are exactly the same on the scarlet and the sound device(default modes auto send the timecode). I always hit the "menu" and the "hdd" button .... then do the menu select on "jam zero". You can now disconnect the yellow BNC connector (atleast I have noticed no drift in a hour), this allows free movement of the camera.
    Hit Record on the 744t and Hit record on the scarlet. Clap your hands ( I was getting some fancy timecode clapper, this ended up working perty good for me and a lot cheaper). Turn power off on the scarlet, then 744t. Take out the red ssd, and the sandisk from the 744t (it also records to internal disk ... so u can also connect the 774t to your computer if u want to copy that way). Copy the RED R3d files to some folder on your computer. Copy the wav files from the sound device to some folder on your computer.
    Final Steps to Verify using adobe premiere, so Open Adobe Premiere (create a project.drag the r3d and wave file into the adobe project).
    ---------------------- next few steps are "optional" ... not sure exactly why some of this happens ---------------
    To shift the audio by one frame (if your having problems with audio offset this is a possible tweak): right click wav file in project panel, select modify -> timecode change frame from 00 to 01, should have "set at beginning" click "ok".
    If your .wav files are not showing the time code in "media start"column ... i.e. the media start time should not be a string of zero's then do this:on the main menu click Edit->preferences->media .... then click on the "media cache database" "clean"also there are three fields there, i'm finding good look having it set at 24 fps, use media source and start at 0 (my manual claps seem to have less frame issues). This btw is some weird bug, will be fixed soon i hope(happens to me every every now and then).
    Back to "normal" things ..... Select the video clip you wish to merge audio clips to. Note that you can only have one video clip in any merged clip. Control-click audio and video clip. right click for menu to and select "Merge Clips" and select timecode. The Merge Clips dialog launches. Choose - Based on matching timecode.
    A new file should be in your project area in premiere, drag that to the time line ... and the sound will be synced. In the timeline, find where your hands clap, zoom into the exact frame, you should be able to see your hands clap at the same exact frame you hear the clap.
    Last edited by PatrickFaith; 01-29-2012 at 07:39 PM. Reason: updated to handle frame sync issues
    http://www.youtube.com/patrickfaithart & http://Pudl.tv
    "Litl" #250 "Pudl" #397 of "Ink" (Monochrome) #3752
    Dec 2009
    Chatsworthless, CA
    Quote Originally Posted by PatrickFaith
    Reset the sound device 744t to "film",,,
    What?
    I have a much easier idea:
    1) set the 744t to time of day
    2) jam the camera to the 744t
    3) roll the 744t and the camera
    4) clap a slate
    5) wait five minutes
    6) clap the slate again
    7) stop the camera and 744t. Remove the files. Bring them into an editing program and lock them together. See if they hold sync from start to finish. If both are at 23.98 (typical), there should be no problem.
    Note that there are typically offsets of a frame or two in many digital camera systems. It's not crucial, as long as it doesn't drift. Note also that this entire process is much easier if you have a timecode slate.
    Multiple cameras are harder, and I also believe the process is more reliable if you put a timecode jam box like the Denecke or the Ambient on the camera.
    www.cinesound.tv | location sound / post-production consultant
    Nov 2011
    Northern California
    Quote Originally Posted by Marc Wielage View Post
    ... Note also that this entire process is much easier if you have a timecode slate.
    Multiple people have recommended getting "Denecke TS-C Compact Time Code Slate" and "Denecke SB-T Time Code Generator / Reader and Tri-Level Sync Box" for the on board camera sync - then doing the connection via them(actually the recommendations are a bit vague ... I'm stating the full name of the products to make sure I'm getting it right). This is about another $2k ... which pushes me over my original [ based assuming scarlet is recording audio] sound budget ... live and learn.
    [did more testing, found i don't need the slate nor the sync box ... atleast for my use cases, also using the slate and sync box required two more cables, which added complexity]
    So modified my steps slightly ... added a physical hand clap ... and a adobe procedure to timecode modify the wave file. (there are about 4 threads that are btw on frame offsets problems, that this method avoids/solves, at least for simple productions).
    Last edited by PatrickFaith; 01-28-2012 at 08:24 PM. Reason: more testing, equipment not needed.
    Dec 2009
    Chatsworthless, CA
    I mean no disrespect, but the other thing you can do is hire a pro sound mixer and have them be responsible for all timecode and sound on the set. The mixer can provide the timecode generators and timecode slates needed without you having to go out and spend $2000 on them (and in truth, it's more like $2300, brand new, for just one SB-T and one TS-3 slate). That way, the camera crew only has to be responsible for the camera, lenses, data storage, monitoring, lighting, grip gear, camera mounts, and so on -- which is more than enough for most people.
    You can also rent this gear from many pro sound dealers, like Coffey and Location Sound. Most of the LA companies will ship to Northern California, and they do weekly rates fairly inexpensively. This will cost you a fraction of the purchase price, even if it's over a period of several weeks.
    Nov 2011
    Northern California
    I mean no disrespect ... .
    Agreed on hiring professionals - on all my normal stuff there's professional mixers, sound engineers, animators, sfx, producers. But industry is so huge/segmented, many of us are really distanced from the sound people (i.e. math/finance guys may comments on talents voice as it relates to demographics, or whine wanting clear voice over realistic audio, but often have no idea even how the mixing/sound is contracted out). The 744t/scarlet is for a personal/charity project I'm doing which would have no chance of funding in the normal process. Thus in the time/quality/$ trade ... I've chosen long shoot time and high quality to focus on, which prohibits renting as being cost effective. Otherwise I agree completely for normal projects.
    Junior Member
    Jun 2010
    Is there a timecode cable on the market that works with Epic an a SD744T other than using these 2 Lemo-to-bnc cables? Both devices uses a lemo connecter for TC but they seem to be different sizes and pins? No cable out there that has the SD744T connector in one end and the Epic connector in the other?
    Nov 2011
    Northern California
    Quote Originally Posted by Aras Taki View Post
    There's a couple of guys in reduser that make up cables, prices are perty good (chime in ... I can't remember their names) ... but I haven't found anything from like b & h where you can just directly order. I have no idea why lemo's are all slightly different, the connectors for the RED i/o module i think will work ??? (i'm doing fairly low cost stuff with the scarlet, but that route might make more sense for you). [added] Their's a x module btw that is perty nice ... which avoids the cable I am using that hooks to the scarlet.
    Way more pro and with less hacky wires then how i did it, but more expensive is a "Denecke TS-C Compact Time Code Slate" with a timecode sync box. I'm going to cut over to this way soon, which will end up costing me another $2k.
    Jan 2011
    Berlin, Germany
    I would like to ask some related questions.
    Thanks a lot for sharing any hands-on experience!
    1) When working without fixed cables between one Epic/Scarlet and the 744t, do you absolutely need to keep a Lockit, Denecke or other TC jam box attached to the camera?
    2) How accurately and how long is the camera holding the TC after getting it from the 744t, when not having a jam box attached?
    3) Is it similar compared to working with 744t and a Sony EX3 (where I never missed having a Lockit and could just jam from the 744t every 3 - 4 hours)?
    4) Will the Epic/Scarlet loose sync, when rebooting or changing the battery?
    I was reading through so many audio posts today, but answers were not 100% clear on this.
    Hope I'm not the only one figuring out, if getting a jam box is a must...
    Scarlet-X #075 "Arletty"
    RPZ 17-50mm
    Angenieux 35-140mm T3.5
    Vantage 14mm T2
    Nov 2011
    Northern California
    Deleting my comments ... Marc's following post is much more definitive.
    Dec 2009
    Chatsworthless, CA
    Yes, you can get custom cables made by all the major Pro Audio companies in the world. In the U.S., I'd recommend Coffey Sound, Location Sound Corp., and Wilcox Sound in LA; Tai Audio in Orlando, Florida; Trew Audio in Nashville and also Toronto; and Gotham Sound and Professional Sound Services in NYC. The SD 744t uses the standard 5-pin Lemo connector, which is used on many (if not most) pro sound and timecode devices. The 4-pin Lemo timecode input on the Epic and Scarlet are not standard on any other camera, but this configuration can be custom-wired with no problem. The advantage of custom wiring is that you can make the cable exactly as long or as short as you need for your particular configuration. Be warned that the Lemo connectors are not cheap (about $35-$40 per connector).
    Quote Originally Posted by Sebastian Winkels
    In my opinion, yes.
    Generally until the camera crashes or is powered down. I have seen cameras drift a couple of frames in, say, a 4-hour period -- and this goes for all manufacturers, not just Red. An external timecode box that has a TCXO (temperature controlled crystal oscillator) is generally guaranteed to not drift more than a frame every 10-12 hours or so.
    The Sony EX3 is a pretty reliable camera in terms of timecode.
    4) Will the Epic/Scarlet lose sync, when rebooting or changing the battery?
    The older Reds did, and in fairness to Red, I've seen the older Sony F900's also lose timecode during a crash or battery change. My preference is always to have a timecode box on the camera, and either run the camera in external or jam it whenever possible, especially on a reboot, a drive change, a battery change, a crash, or when the crew takes a long break (like lunch).
Tags for this Thread
View Tag Cloud
