Thread: RTMotion Wireless Follow focus review
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. #1 RTMotion Wireless Follow focus review
    REDuser Sponsor Andy Jarosz's Avatar
    May 2009
    Chicago
    I've had this unit for about a week, but was delaying the review because I was waiting for a firmware update. Now I have it, and I feel confident it's time to thoroughly review this guy! This review is on their newest system for sale, the Mk3 digital motor and receiver and the Mk2x5 controller with firmware build 1.0.1b. I also received a Pelican case from them.
    First impressions
    The first thing that struck me was how well built it was. The motor and receiver are both CNC machined, solid, black finished aluminum. The controller is an extruded aluminum case. Everything feels weighty and without a doubt professional. If this is at all a concern of yours, don't even worry.
    With the controller, the first ting that I noticed was the knob. It's a solid piece of machined aluminum and it feels fantastic. I'm not sure what voodoo they've put into it, but honestly it's a joy to use. It glides as you spin and has a sort of dampening when you hit each end stop. They claim 400 meters for range (which is just under a quarter mile!) And while I haven't verified it has that long a range, I have never lost a signal while using it. It has interchagable antennas, so I'd be curious to see if the range increases if you use bigger antennas.
    The receiver is *tiny.* It supports three motors at once, and feels tough. Latency on the whole system is very minimal, and while it's there I don't personally feel it's enough to cause any issues. If it does, it has three different smoothing modes ranging from "oh god its butter" to "race car on a fighter jet." You can also fine-tune the response on the fly.
    The motor I feel the same as the receiver. While it's a normal size, it feels beefy enough that it can take a beating. It has interchangeable rod clamps which are very easy to use.
    What can it do?
    The amount of features packed into it is also fantastic. This whole kit is 3d ready, with features like custom lens offset points and 1:1 tracking that you wouldn't expect to find on a unit this price.
    Another cool feature are the focus "light helpers." Basically, you can set up to 30 points where the LED lights up when you go over that point, making a sort of "soft mark."
    The downside, and why I feel the controller is the weakest part over all is twofold. First, the menu system is entirely based on a single RGB LED. This means you either have to memorize the "light pattern" combinations or use the manual. I used the blank space on the back of mine to make a little "cheat sheet" and luckily there's only about three you really need to know anyway. I would have loved to see an LCD screen, perhaps in later incarnations. Second, the marking disks are currently not interchangeable a (in my opinion) critical oversight. However, they will very soon release a fix for this.
    The receiver, as previously mentioned, is small. It fits into the "fillet" under the SSD module on an EPIC or Scarlet (if you're using a bottom space plate) so it takes up essentially no room at all. It also automatically calibrates the lenses, manual calibration is not yet enabled. Yet in that small space it can do three motors, start/stop and power. They sell start/stop and power solutions for just about any camera and more are coming.
    The motor I have mixed feelings on. It's very powerful and very quiet. It drove the Red Pro Primes with ease and it did it essentially silently. So on those fronts, the motor is incredible. However, the gears require three screws to change and are not flippable. This can limit your options depending on the setup, E.G. if you're using a DSLR system. For some this won't matter, for others it may. Luckily, they are working on another receiver which can use third party motors so this may not be a concern much longer.
    In practice
    What's great about the system being so low profile is that it almost takes up less room then a regular follow focus! Stedicam ops will love this system as there are so many more options on where to place the receiver that it almost basically becomes a non-issue.
    They provide many power options, I have the DTAP and 4pin XLR cables which works great. All their cables are very high quality and flexible. I believe you can also ask for custom lengths.
    As I said before, latency is very low and acceptable. It's no more than any other system.
    The system also has special software that allows you to hook the receiver and motor up to your PC via USB. This is how you do firmware updates, but it also has a program that allows you to program simple timelines and control motors over time. It's a WIP right now, but it seems very promising for time lapse and motion control. Firmware updating is also super painless, and apparently it uses a "safe, modern bootloader" which means you can lose power in the middle of a flash and it will be totally safe.
    Finishing up
    At this price point, with these features, I can honestly say this system will make you go "Bartech? What Bartech?"
    It's not a Cmotion, but you didn't expect it to be. For the price, you simply can not beat it. Their customer support is amazing, and they're constantly coming out with new toys and upgrades which fits in the RED philosophy of "future proof." I wish they had an LCD screen for the controller and I wish the motor had a couple more features, but this is a very solid system.
    I have just one question: Why is it called RT Motion?
    Let me know if you guys have any more questions! Pics coming in the next post.
    AC and owner of MadlyFins, LLC
    Chicago, IL
    708.420.2639
    andy@andyfilms.net
    www.madlyfins.com
    May 2009
    Chicago
    Chicago, IL
    708.420.2639
    andy@andyfilms.net
    www.madlyfins.com
    Senior Member Ryan De Franco's Avatar
    Oct 2010
    Brooklyn, NY
    Excellent, been looking forward to this for a while now. Might seem dumb, but you can of course increase the rotation on the controller to get a high gear ratio for small lenses and short pulls? This is the biggest draw for me, so my assistant can pull the 5 degree turn between 6' and 8' on the lens with a nice 90 degree turn on the controller.
    Have you had the chance to use the new Bartech Digital system? Any thoughts between the RTMotion, Bartech and Preston (with either Heden, M-1, etc motors)? Curious about any differences in terms of lag, "feathering out" on the motor, ease of use, etc. Thanks very much for posting this, and let me know if you're ever in New York, I'd love to buy you a drink and test it out for a minute or two.
    May 2009
    Chicago
    Quote Originally Posted by Ryan De Fanco View Post
    It currently maps the entire lens to the whole "spin" of the knob, so they're as "played out" as they can be. You can't currently set a custom mapping (you could easily do this with a custom calibration) but I wouldn't put it past them to do something like this in the near future.
    Have you had the chance to use the new Bartech Digital system? Any thoughts between the RTMotion, Bartech and Preston (with either Heden, M-1, etc motors)? Curious about any differences in terms of lag, "feathering out" on the motor, ease of use, etc..
    I haven't had a chance to play with the Bartech digital receiver, but if it's the same as the analogs then it's just as good. It's hard to make a judgement here because I don't have concrete numbers, and I don't have them side by side, so I can only go by "feel." That said, it feels great and I wouldn't mind using it to pull focus.
    As I mentioned in the review, it has three different smoothing modes which adjust the levels of easing in and out of the pull. So the fast mode zips along but can be a little jerky because it's registering every tiny move. The smooth mode will ease in and out a lot, but because of this it creates the apparent feeling of sluggishness. My favorite mode is the middle mode which combines the two.
    Chicago, IL
    708.420.2639
    andy@andyfilms.net
    www.madlyfins.com
    Oct 2010
    Winnipeg, Canada
    Hi Andy,
    This is fantastic! Thanks for your review. As soon as they have stock we are picking up a 3 ch system.
    Have a great day!
    Oct 2010
    Winnipeg, Canada
    Andy,
    How do you do a zoom and focus at the same time?
    THX
    I have two of these units...solid...solid...solid! The motors mirror for 3D...four right now and
    More with "affordable" breakout box. BTW the knob on top of the controller is for independent zoom/iris.
    May 2009
    Chicago
    Correct, the knob on the top can control zoom and Iris. You can't do both at the same time, but you can switch it on the fly between them.
    The motors store their "designation." So if you set one to zoom, it doesn't matter what port you plug it into from then on, it's always the zoom motor. Likewise for iris and zoom. You can change these designations at any time.
    Chicago, IL
    708.420.2639
    andy@andyfilms.net
    www.madlyfins.com
    Jul 2009
    Delft, Holland
    I bought one some weeks ago and it works like a charm! lightweight; highpower, very quiet unless you rack from 0-360 in a fraction of a second.. hard to beat price-quality point in my humble opinion; they have announced removable disks and future firmware updates should bring manual calibration in which you should be able to map 5 degrees on your lens to your 360 on the knob. only thing that is a bit flaky in my set-up atm is the start/stop recording function.. but i also have an origo so it could be that i have to look into port settings on my red.
    Oct 2010
    Winnipeg, Canada
    Pardon my stupidity. So, you can use the follow focus knob (main one) for focus pull but at the same time you can use the small top knob for say zoom?
    THX
