Thread: x A-Box & Neumann 81i
Results 1 to 6 of 6
  1. #1 x A-Box & Neumann 81i
    May 2010
    Atlanta, GA
    Hi!
    Does the x A-Box supply 48v phantom power? I couldn't tell.
    Is there a better way to run XLR into the Scarlet?
    Senior Member Terry VerHaar's Avatar
    Sep 2009
    Silicon Valley, CA
    The A-Box will pass phantom power through - but it has to be enabled on the Scarlet for that to happen.
    Aug 2007
    Is phantom power enabled on Epic?
    M
    May 2010
    Atlanta, GA
    Okay good to know, thanks! I didn't realize that phantom power could be passed through the 1/8 front ports. You learn something new every day.
    Dec 2009
    Chatsworthless, CA
    Quote Originally Posted by Adam Pitchie View Post
    I think you're a lot better off using an outboard mixer.
    The Neumann 81i is a very, very good microphone -- in fact, I'm pretty certain it costs more than a Scarlet ($1600). If you're going to put it on the camera, I think you're better off with a cheaper mike, and putting the Neumann much closer to the actors or interview subjects, on a boom.
    www.cinesound.tv | location sound / post-production consultant
    May 2010
    Atlanta, GA
    I will use it in that configuration too, but I'm also using it as a run and gun microphone. It's just that with certain projects, it will be the shotgun mic and I won't be allowed to use booms.
    Also thinking about getting the Neumann RSM 191-AS :)
    Any feedback on the RSM? At that price point would it be wise to consider a Schoeps?
