Thread: OConnor/ Anton Bauer AND Scarlet!!!
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 39
  1. #11
    Jun 2009
    Los Angeles, CA, USA, Earth, Solar System, Milky Way
    Quote Originally Posted by Adam Michael Carr View Post
    With the O-Focus and the O-Box mounted on the Scarlet, do I need a riser?
    Quote Originally Posted by Eric J. Johnston View Post
    With 15mm LWS rods NO you do not need an adapter for either the O-Focus or O-Box (they both are native 15mm LWS brackets.)
    Correct me if I'm wrong, but for Epic and Scarlet you would need something like the Red DSMC Modular Assault Plate Pack, x Easy Riser/15mm LW Bracket combo, or Viewfactor FMJ Bottom Plate/15mm LWS Bracket, right?
    Mar 2011
    Toronto, ON Canada
    Quote Originally Posted by Mike Halper View Post
    What you see pictures there is the Anton Battery plate:
    http://www.antonbauer.com/Products/QRC-EPIC
    And the Matrix Cheese Plate:
    http://www.antonbauer.com/Products/MATRIXCheesePlate
    This solution works only if you have 15mm rods. You could use this config as a shoulder mount too with the matrix mounted to a shoulder rig as a counter weight.
    ___________________________
    10 frame handles
    Vimeo
    EPIC-X "SHAI"
    REDuser Sponsor Eric J. Johnston's Avatar
    Apr 2009
    New York
    Exactly Correct Mike. The height of the camera body is such that the camera base is lower than 85mm optical center to center rod clearance needed to have this long established standard align. So what all the plates you mention are doing is moving the 15mm LWS bracket forward and up in front of the camera base; therefore the rods can only extend IN FRONT of the camera.
    With 15mm or 19mm studio rods, they sit significantly lower when measured from the optical axis so you have the room to attach a baseplate where rods can extend both in front and behind the camera body.
    Check out the paper I wrote about rod standards with diagram here for further explanation:
    http://www.ocon.com/labs/rod-standards.html
    Eric J. Johnston
    Paralax Productions
    eric@paralaxproductions.com
    Apr 2009
    New York
    Actually the Matrix plate is tapped for all three rod standards. It has the option of two sets of rod clamps; one 15mm and one 19mm. These can be adjusted for 15mm LWS, 15mm Studio and 19mm Studio; as pictured.
    Eric J. Johnston
    Paralax Productions
    Apr 2009
    New York
    Quote Originally Posted by Cid J Salcido Uyarra View Post
    ok just did my research I'm pretty much sold on the O-focus
    been looking at the Letus and RRM Blue but I'd rather save up the extra dough and go this route.
    You guys are coming from the cinema angle v the 35mm adapter angle. You guys know what you're doing.
    Thanks Cid for the compliment! It comes from the years of experience our core team has in the specification, design and manufacturing of some of the best motion picture equipment on the planet. Feedback from all of you goes a long way as well!
    Eric J. Johnston
    Paralax Productions
    Senior Member Mark Phelan's Avatar
    Oct 2007
    Eric, how is the camera attached to the 1030Ds?
    Senior Member Matt Gottshalk's Avatar
    Potomac Falls, VA
    Good stuff.
    I LOVE my CFF-1!
    Matt G
    http://www.mcgeedigitalmedia.com
    EPIC-X #00740 "Decker"
    Duclos 11-16mm
    RPZ 17-50mm
    Red 50-150mm
    Senior Member Satsuki Murashige's Avatar
    Aug 2009
    San Francisco, CA
    Hi Eric, please check you PMs, I sent you some feedback on the oFocus a few weeks ago.
    Apr 2009
    New York
    Quote Originally Posted by Mark Phelan View Post
    Hi Mark,
    The new 1030 has the same sliding lock plate as the previous version with the standard OConnor quick release plate (this sliding lock plate can be turned around so the release mechanism is in the front or back of the camera- depending on preference.) The quick release plate has one ¼ and one 3/8 screw attached to the RED Dovetail Mounting Plate which is then mounted to the RED Quick Release Platform attached to the camera body.
    Eric J. Johnston
    Paralax Productions
    Senior Member Nick Wernham's Avatar
    Oct 2011
    Toronto, ON
    This looks like some really great stuff. I am definitely interested in some OConnor accessories.
    C.E.O. of Wernham Entertainment Inc.
    Current Project(s):
    "Business Ethics" [Completed Short]
    "Public Service" [Short in Post]
    "No Stranger Than Love" [Feature in Pre-production]
    Co-Owner of Epic-X #3805 "Hentgen" & Scarlet-X #557 "Stieb"
Tags for this Thread
View Tag Cloud
