Thanks Bruce. I understand the ability of the larger space to comfortably encompass and represent the smaller space, but I thought the BITS were too spread out (wasted) on a larger than necessary space, resulted in potential for banding and such?
Sony now talking about their x65 4K camera and 4k theater and 4k projector at CES.
OOOH 4K TV
SHV color standard is wide gamut but 12-bit so that is not a problem :)
Bruce Allen
www.boacinema.com
Whatever timetable for the widespread adoption of 4K you predict, that's really just a question of time. Yes, I understand that impacts the viability of the technology in myriad ways, but several of the issues Bruce cites need to be addressed sooner than later. Sure would be nice to see an provision for including a 3D LUT in the file header that can be imported into the display device, perhaps as a basis for automated calibration routines... At its most basic level it would provide a protocol that could read color space flags like rec709 and implement the correct adjustments for that particular panel.
Disclaimer: I would really like to develop a technology for creating personalized LUTs mapped to the visual response curve of the viewer and this would make implementation much easier ;-)
Creating a standard that strikes an elegant balance between quality and the mechanics of creation/delivery in a rapidly evolving technological time is a serious challenge. In just the last few pages of this thread there were references to bit rates and delivery systems in the context of a rather wide variety of usages - each with its own market dynamics. There was general acknowledgment of the greater viability of open standards (or very low cost licensing) combined with mass market economic drivers. At the very least I/O standards need to be in place that are not silly expensive to implement and have massive headroom for higher speed variants down the road.
As an example, the first consumer targeted 4K projector I know of is the Sony ES-1000 and it is fitted with a single HDMI 1.4a port as the only way to feed it 4K. AFAIK this limits it to 4,096 by 2,160 at 24fps (23.976) and 3,840 by 2,160 (QHD) at 30fps (29.97). I understand the desire for a single cable solution and doubt the clock rate of the projector could do much more anyway, but how would you feel if you paid $25K for a projector that could never even do full res 4K S3D at 24 fps? In the past, some manufacturers of next generation hardware have used outboard processing boxes to feed display devices over proprietary connections as a stop gap until common interconnect formats catch up.
I call for a connection standard capable of playing back 4K S3D at 60fps. That should hold us a good long time. Quad link 3G SDI? HDMI multi-line snake with a hydra head?
FWIW I am not convinced that 8K is really going to catch on due to the physical characteristics of the wetware (human vision/size). I believe that even when prices drop, very few people would want a home screen with a diagonal of greater than 120" (slightly more than 3 meters). Even in a dedicated home theater, if you mounted it right up to the ceiling in most houses the bottom of the screen would be too low for comfortable viewing. So unless you fill an entire wall and sit closer than 5' the difference between 4K and 8K would be hard to discern. This is an analog to the argument about 4K vs 1080 on a 50" panel from 8' away. The big difference is, that panels will go beyond 50" and display devices live in a lot of places these days besides a traditional living room seating arrangement. In the theater, due to the limited number of arc degrees of high visual acuity we possess, you can only get so close before you can't keep the edges of the frame in your visual field. I wouldn't argue the point that a well crafted viewing environment with next generation display tech could show the difference between 4K and 8K, what I am saying is that in the real world issues unrelated to technology per se, but simply the reality of our physical bodies and the physical spaces we consume media in, will make that differential too small to justify much in the way of greater expense. Bottom line:
1) Theatrical: with the buzz about 3D already fading, 4K will be touted as a reason to go to the theater vs staying home so the trend of features being DIed at 4K will take off and, down the road, 8K for theatrical might serve a similar purpose.
2) Home: as display tech evolves, the difference between 1080 and 4K will be significant enough to impress the mass market and as soon as the price point hits the tipping point it will catch on.
As Mike noted some standards live very long lives (for a variety of sometimes unexpected reasons). Let's look at choke points on the delivery side that might motivate compromising best quality for expediency. What number of desirable (demographically speaking) households will be able to receive OTT (IP based distro, not MSO/"broadcast") minimum download speeds of 25mbs within 5 years? If that number is too low, then we run the risk that in a rush to monetize a technology too soon, it is compromised so much it misses the wheelhouse of its potential.
I would hate to see us repeat the sorry state of most digital music distribution these days where bit starved implementations of codecs never designed for those rates yield proxy level quality that is sold as "pristine, digital, ...".
Cheers - #19
I remember when the folks at cinematography.com told us that 4K screens for the home were at least 10 years away... and were "unnecessary."
I have lost count on the number of 1080p/1200p 10 inch tablets and QHD/4K monitors I have read about at CES 2012. Between these we even have near-3K ultrabook laptops. Panasonic is flaunting a 20.4" 3840x2160 IPS-Pro panel monitor that is apparently just 3.5mm thick. Looking forward to a 3840x2160, 24 inch, sub-$1000 IPS display sometime in 2012. Although considering my viewing distance 3200x1800 will be adequate.
I think that the challenge for 4K believers is persuading someone with room for no more than a 42" TV that the picture quality is dramatically better than 1080p. So while the producers of big budget shows will have an eye on future revenues and will doubtless start to prefer to master in 4K, I don't yet see that if a consumer only has a 42" screen (4K or 1080p), that an old 1080p TV show won't scale and look just fine. It's certainly not going to be a deal breaker is it?
Interestingly, the Sony F65 has an available color gamut that appears to be identical to SHV color space:
I have no idea how easy or how hard it'll be to reproduce this color space in the real world, but it is interesting that Sony built this in to the new camera.
Yeah... but it's incredibly compressed 4K. 4K that stutters, has bad motion problems, and looks real blocky is not good 4K. Throughput is a real killer, and let's also not forget about bandwidth caps.Originally Posted by Jeff Kilgroe
I have never seen the DPs and members of the CML agree on anything or make a unified statement. One or two people might have said that, but not the group as a whole. If anything, they disagree more often than they agree, especially on stuff like 1080 vs. 4K.
The issues really boil down to moving this much data back and forth. I believe the post articles on Girl with the Dragon Tattoo indicate that the final 2-1/2 hour movie boiled down to 55TB of data. You know how long it takes just to copy 55TB of data and back it up, even on very, very fast drives? Call up your cable provider and ask them what they would do if you tried to download 55TB of data in a few days. Even if you could compress this 10:1 to 5TB of data, even that takes hours and hours to do. Last time I checked, I think it takes about 6 hours to copy 1TB of data on eSATA -- somewhat faster via FiberChannel and a few other connections.
All of this stuff is gonna happen someday, but me, I'd like to see HD perfected on consumer monitors before we move on to 4K.
Panasonic's 3840 x 2160 20" LCD is not designed for multimedia production, but for specialized purposes, such as medical and industrial.
Which means priced accordingly.
