Click here to go to the first RED TEAM post in this thread.   Thread: Timecode issue with 3D Epic
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
  1. #21
    Almost forgot. Playback is not synchronized between the cameras.
    Member David Barlow's Avatar
    May 2009
    Southampton UK
    Yeah. Playback of high speed shots a half second out of sync can be quite surreal. However, seeing the high speed played back immediately is invaluable.
    Senior Member Arnaud Paris's Avatar
    Jan 2007
    Paris, FRANCE
    Can somebody confirm that the moded Denecke SB-T for 3D is a valid option for high framerate on Epic as a factor of 25fps?
    Arnaud Paris - Stereographer
    www.stereocorp3d.com
    http://twitter.com/3D_red_paris
    4K Digital Cinema in Paris
    Sep 2009
    Ft. Lauderdale, FL
    I have many hours of 3D on my Scarlet rig using a modified Denecke SB-T and it has been ROCK SOLID for sync and timecode.
    Jan 2007
    Paris, FRANCE
    Thanks David, but since you're using it with Scarlet I imagine you don't go in really high frame rates.
    Is somebody using it with Epics up to like 250 or 300fps with rock solid results as well?
    Senior Member Ross Isaacs's Avatar
    Sep 2009
    Port Douglas, Australia
    Quote Originally Posted by Dave Winder View Post
    The issue with genlock signal is that a 'T' essentially doubly terminates the signal, cutting the level in half. This leaves it very close to the lower threshold required by the circuitry in the camera. Depending on the genlock source this may or not work. Therefore, RED does not recommend using a T.
    An Ambient Lockit for example becomes marginal. But, Ambient does have a mod available that provides two genlock output connectors. A Lockit with a T often works 'OK' going straight into the 3BNC-lemo cables. But its not guaranteed.
    As for timecode alignment, the cameras are not guaranteed to start record on exactly the same frame. Using the GP Input as a trigger with a single button T ing to both cameras will get you the closest you can, and it is very close, as in a couple of frames. RCX will then usually line them up automatically by timecode. Framerates off the project rate will have more variation. Using a slate is recommended. Using the GigE cable to control record on both cameras will have more variation in the start of the record since there is delay to relay the commands to the slave camera.
    High framerate synched recording is supported. Its not a fluke.
    I am just about to purchase an AMBIENT ACL 204 for Time code generation and syncing 2 x Epic Xs on a 3Ality Technica Atom rig. I have the following cables from RDCC. Can you tell me if I will require any other cables or accessories to make this work?
    1 X Ambient ACL 204
    1 x Master/Slave GIG-E cable (4')
    2 x 3BNC-To-OO Sync cables
    Director/Producer
    Ocean Planet 3D
    http://www.oceanplanet3d.com
    Ocean Planet Images
    http://www.cyberdiver.com.au
    Pathfinder rebreather diver armed with Deep Atom
    RED ONE in GATES DEEP RED underwater housing
    EPIC X in GATES DEEP ATOM underwater housing
  7.   Click here to go to the next RED TEAM post in this thread.
  #27
    I dont have experience with the 204, but since they are purposefully supporting dual load, I would say this is the correct shopping list with a few additions needed.
    You will need the T adapter for the genlock, and two of the TC lemo to BNC adapter cables (not a RED item), or one cable and a T. Timecode handles the T-ing better. like these
    http://www.ambient.de/en/produkte/am...l/ltc-out.html
    http://www.performanceaudio.com/buy/...s/XL_LB2/27072
    I have used the second one.
    Sep 2009
    Thanks Dave
    I believe some of those other cables come with the Ambient 204.
    Director/Producer
    Ocean Planet 3D
    Ocean Planet Images
    Junior Member JP Perry's Avatar
    Aug 2008
    We have found the old SB-T and the new upgraded one to both work the same. Are we just getting lucky with the old one? Trying to decide if we should upgrade all units or keep going with what is already working.
  10.   This is the last RED TEAM post in this thread.   #30
    In my opinion, you are getting lucky. If you can, I would recommend upgrading so you are ensuring the proper signal levels.
