Epic and Red One Digital Cinema Cameras and Accessories Available in New England and Beyond
SPECIAL RATES FOR STUDENTS AND INDIE PROJECTS!!!!
More accessories and camera support available.
Also other camera brands available for rent at our website: www.EquilibrioFilms.com
Contact me if you have questions 1(646) 397-9498 or for rush rentals email to contact@equilibriofilms.com
EPIC Daily Rate: $750.00
Package includes:
EPIC-X Brain titanium PL mount
Bomb EVF® (comes with 5” RED ARM and 18” LCD/EVF Cable)
5in Touchscreen LCD (comes with 7” LCD/EVF Cable and RED MicroFiber Bag – Medium)
DSMC® Side Handle
DSMC® Side SSD Module
Red Station
REDmote
1x 256GB SSD card
4x REDVolt batteries and travel charger
Custom laser-cut foam EPIC Pelican 1510 case
RED Quick Release Platform [Dovetail]
DSMC® Universal Mounts 19mm
Dovetail Mounting Plate [Long] (for non-ARRI heads)
2 x 19mm Carbon fiber rods 24 inches.
Red Quickplate
2B-to-1B Power Adaptor Cable
Blushape 210W Battery up to 4 Hours of uninterrupted power.
Bebob2 Charger
DSMC® AC Power Adaptor
The Glidecam Smooth Shooter for Epic Cameras Daily Rate: $250.00
Package includes:
Glidecam Support Vest
Smooth Shooter Support Arm
Docking Bracket,
Stainless Steel Arm Post,
Aluminum Arm Post,
Red Quickplate
15 Counter weights discs.
Red One Daily Rate: $350.00
Package includes:
Red One Body
Red One Side SSD Module
RED 18-50mm T3 ZOOM (I)
Matte Box MB4169H-2M With 15mm Adaptor and 2 15mm Carbon Fiber Rods
FF RFF-15B Cavision
Red Onboard LCD w/ Cable & Arm
Red EVF with Red arm and Interface cable
Simultaneous Charger
(2) Red Brick Batteries
1 320GB Red Raid Drive (up to 2hours 4K video recording).
256GB SSD card
Red Station
Mini XLR Cable
Mini BNC to BNC Adapter
Red Base plate w/ Shoulder Mount
2 Universal Mount
2 Top Mounts
Top Handle With Extension
Right Handle
Red Cradle (Including Battery Plate)
2 24" Steel Rods
2 18’’ Steel Rods
2 12" Steel Rods
Glidecam Camcrane Camera crane system Daily Rate: $150.00
Specification and package includes:
• Holds cameras up to 25 lbs at the 8 ft. length, and 30 lbs at the 6' 6" length
• Four boom length combinations: 3' 3", 4' 10", 6' 6" and 8' 1"
• Three fulcrum (balance) settings
• Can vertically boom from the floor to 10 feet when setup at the 8 ft. length (variable)
• Rotates 360 degrees via precision, low-deflection, needle roller, turntable bearing
• Mounts on the 3/8" standard bolt found on the majority of medium duty tripods, and some heavy duty tripods
• The Head of the Crane has 3/8" mounting holes/slots.
• The complete system weighs 19 pounds (approximately).
• Fits easily into the trunk or back of a car when not fully assembled at 3' 3" long
• Heavy barbell weights are included.
• Fine tuning counter balance weights are included.
• Tripod included.
