Originally Posted by
eclaire
Philip, while very respectful of your obvious knowledge and credentials, it seems you are striving to prolong an artificial debate when I don't think there is any substantive difference of understanding (and apparently you are selectively doing so, as the post of mine you quoted was merely an affirmation of something 10s posted). A limiter IS like a one-legged compressor -- it does exactly the same thing to signals exceeding a specified amplitude that a compressor does but usually does it at a much sharper curve/faster rate and usually kicks in at a higher threshold frequency. Most dedicated hardware limiters are not called "limiters": they are called "limiter/compressors", and that's because the functionality between the two systems is so overwhelmingly similar. Specifically WRT software compressors, you could program one to do exactly the same thing to a file that you could do with a limiter, and you are very likely to not even FIND a plugin in major programs today called a "limiter" but rather one unified plugin that manages dynamic range and fulfills the overlapping functions of a limiter and a compressor.
If, for example, you look at the flagship DAW from Cakewalk Audio, Sonar, you will see that it doesn't offer a "limiter". Limiter functions are subsumed within and are a subset of the functions of their Sonitus compressor. (See the attached screenshot.) In Sony Vegas, you will get a choice of several "dynamics" plugins (ExpressFX Dynamics, Multiband Dynamics, Graphic Dynamics), all of which feature the same basic parameters for adjustment.
With a programmable limiter (hardware or software), you are setting the level at which you wish to begin amplitude attenuation, you specify the ratio of attenuation to be applied to amplitudes exceeding that threshold, and you set the amount of time in milliseconds over which you will allow the gain reduction to reach its maximum and return to passivity (when signal input again falls below the threshold). With compression, you do exactly the same thing, attend to exactly the same parameters, only you also specify some amount of input boost, which may or may not be constant and the implementation of which (attack, release times, low threshold levels, etc.) will vary depending upon the compressor. The continuum of dynamic range control typically connoted by the respective terms ranges from "brick wall" attenuation of only very, very high peaks with an overall preservation of wide dynamic range to a very consistent, compact dynamic range with ample input boost and often an increase in both perceived volume and actual average amplitude.
With what part of that description do you take issue? If you google the words "limiter compressor differences", the first 5 hits you get will say essentially what I've said above, and most make a point of acknowledging the pronounced kinship between the two terms and devices. I really don't see what you are so determined to refute or what I've said that should seem in any way controversial to a seasoned audio professional.
