Wow, glad this thread was useful. Thank you everyone for all the appreciative posts.
Totally agree on the philosophy of figuring out the shortest path to get the job done.
Also yes, as noted 8-9-10 are a horrible kludge :) Much better to do in one node - like a confident Picasso brushstroke instead of just doing 100 timid strokes...
Agree - Alchemy takes place in the wrong place for me. I would want to do color grading / noise reduction / CA correction etc before adding any mist effects. It doesn't fit into a VFX workflow either - if you want to add something CG to a shot... you can't add Alchemy stuff to match.
Sure it is nice for many people... but I'd much rather RED just focused on making R3Ds decode faster!
Well, only those two shots that Tom needed help on. The others did not urgently need extensive corrections.
Also, they don't take that long when you're in the program. It took me a heck of a lot longer to make that tutorial than it did to do the color correction work!
For this shot, I sent him DPX files over DropBox, compressed into a couple of big zip files with 7-zip to get the file sizes down.
For the second shot, I sent over as EXR B44 - a lossy format which is compact but incredibly close to the same quality. Transferring DPX would have taken too long and the deadline was close.
Apparently Premiere can't read EXR (hope this changes in the future!) so Tom had to load the EXRs into After Effects and export as DPX. But since transfer times were the bottleneck, it was the right move.
Bruce Allen
www.boacinema.com
