Thread: Calibration
Page 5 of 5 FirstFirst 12345
Results 41 to 50 of 50
  1. #41
    Senior Member Mike Lary's Avatar
    Mar 2011
    Seoul, South Korea
    Quote Originally Posted by Danai Chutinaton View Post
    Mike, I couldn't find a price for THX's cineSpace HD. Do you know approximately how much it costs?
    cineCube HD is around $1900, but you should contact them directly for a quote. They're very responsive to pre-sales inquiries, so don't be discouraged by the lack of information on their site. SpectraCAL is also great in regards to pre-sales. Both are top notch companies that can answer any questions. Both products are very solid as well.
    Mike Lary
    Director of Technology, DIGITAL FACTORY, Seoul
    Digital Revolution Since 2009
    Color Correction/Digital Workflow/Red Camera Rental
    www.DigitalFactory.kr
    Jun 2009
    Los Angeles, CA, USA, Earth, Solar System, Milky Way
    dispcalGUI created the IRIDAS .cube LUT and it loaded in Resolve just fine. I did it as a test on my MBP display, which actually isn't a good idea since I'm using the color profile via the OS display preferences anyway. So I'm going to try it on one of my LCD's and see how well it works. Just a warning... if you use the highest quality settings for the measurement and profile creation it takes about an hour on my i1 Display 2. It does A LOT of measuring... hundreds or gradations of colors.
    EDIT: I ran dispcalGUI on my Samsung LCD, saved the profile, and then created a 3D LUT. Loaded the 3D LUT into Resolve and it looks great! Thanks, Danai, for the explanation on getting the calibration to translate using LUTs! And thanks Von to you as well for your help with my questions.
    Feb 2011
    Bangkok, Thailand
    Hey, that's great news regarding dispcalGUI! Haven't had the time to test it out myself yet but will do so soon.
    Danai Chutinaton
    Scarlet X #2264
    Dec 2009
    Montreal
    i1 Display pro (OEM version) is a very good measuring device. Not sure how DispcalGUI measures up (bad pun...) to the paid software, but I will give it a run. Lightspace has given us a very high standard of result.
    Calman DIY version is a quick/easy way to get things close first - you want the curves to do as little heavy lifting as possible. Definitely any consumer Panny plasma (OK, at least the THX ones) can fully display correct rec 709 for grading purposes. However, I would steer clear of the VT50 as it has non-defeatable sharpening. I would TOTALLY stay clear of LCDS and LED (which are just LCDs with LED backlights) displays, unless they are approved for pro use (and thus more expensive than that plasma). In other words, no competent pro uses a BestBuy LCD or LED display for grading.
    Senior Member Alexander Mejia's Avatar
    Jun 2008
    Champaign, IL
    You can use DispcalGUI to convert your existing .icc you've generated for your monitor into a LUT that will get you to whatever color space you want. This worked for Speedgrade, but I'd imagine it would work for Davinci as well.
    This means you can still use the calibration software you're familiar with to use a single monitor to make accurate grading decisions. You would still need to work up a profile to directly control SDI attached monitor since Windows 7 will not color manage that.
    http://forums.adobe.com/message/4554810#4554810
    Alexander Mejia, Video Editor, Colorist, and Compressionist Volition-Inc/THQ-Inc. @Alexander_Mejia
    Jun 2009
    As I mentioned in 3 posts above yours it does work in DaVinci Resolve.
    Senior Member Christopher Barrett's Avatar
    Sep 2010
    Chicago
    All very interesting. Coming from a stills background, I've always retouched on an Eizo profiled with an i1 Pro Spectrophotometer. When I started grading in Resolve I hooked up my new Flanders via the Decklink card. And, surprisingly to me they were really very close. BlackMagic has a Photoshop plugin that allows you to view an image on the display hooked up to the DeckLink card. Looking at an image there and the same on my calibrated Eizo made me very confident in my old system. The Eizo was slightly warmer and the Flanders had a slightly nicer contrast range... but they were very close.
    My 2 cents.
    __________________
    I DP'd the hell out of that shit.
    The Website
    So I now have a Decklink HD 3D and I'm waiting for a CalMan Enthusiast bundle with the spectracal C6. I've been looking into this for a long time and it felt like the best choice.
    Though, I'm a bit scared about the compability between the C6/CalMan and the DeckLink HD 3D.
    Hopefully I'll be able to calibrate with this, but it would be great to hear thoughts about it.
    Quote Originally Posted by Christoffer Glans View Post
    Hi Christoffer, can you please describe how you are planning to implement this system? How and what will you be connecting to for inputs and outputs and what display(s) will you be using?
    At this moment I only have an LG RGB-LED LG w2420 as a monitor connected with HDMI out. The HDMI is coming out of the DeckLink HD extreme 3D and I'm using DaVinci Resolve Lite at this time.
    (I also use it with After Effects, Avid and Adobe Premiere).
    Is there any calibration footage/plates that I can run through Resolve and calibrate so that I get the best possible image output?
