Thread: Small microphone option for the Epic
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Senior Member Olivier Madar's Avatar
    Asnieres (very near Paris)
    I have tried Sennheiser G3 HF mic with the apppropriate cable (mini -mini from receiver). It doesn't work (I hear something but it is useless).
    Olivier
    Epic dragon, scarlett, K5600, Dedolight
    Paris
    The frenchie doc
    Senior Member jimhare's Avatar
    Sep 2007
    Sydney Australia
    This does actually work. The trick is not to use the "appropriate" cable. Instead use a $3 1/8" to 1/8" cable from Radio Shack.
    The Epic is not working with balanced signals at the moment so the TRS assignment needs to be straight through, not balanced.
    I have all audio solutions working, from Sennheiser G2s to stand alone mixers, and even the headphone jack of a Red One! I picked up a few cheap cables so I'll always have a working one.
    Quote Originally Posted by Olivier Madar View Post
    Olivier
    Thank you for the info. I will try it soon.
    Olivier
    Paris
    The frenchie doc
    Senior Member Steve Wake's Avatar
    Dec 2009
    SF Bay Area
    Olivier
    Just to remove any mystery:
    This doesn't work because the cable you tried - Sennheiser CL-1 - is designed to be plugged in to a Stereo DSLR or consumer cam input. It is wired (Receiver end first) T-->T AND R, R-->0, S-->S In other words, it is dual mono, with the tip on the receiver end connected to both ring and sleeve of the camera end. Actually, this should work with the Epic audio jack set to unbalanced IF the ring of the jack is open (no connection to ground or anything else) when set to unbalanced. Unfortunately, there is no pinout diagram in the manual for the unbalanced position.
    Quote Originally Posted by jimhare View Post
    This works because the Radio Shack cable is simply wired T-->T, R-->R, S-->S The ring on the Sennheiser receiver side is open/no connection. So you get a clean unbalanced signal into the camera audio jack through the tip and the sleeve.
    To go from a stereo headphone feed to the audio jacks I assume you're using a splitter that's wired T-->T(channel1), R-->T(channel2), S-->S(both channels)
    Anything that works now should work when balanced input and phantom power are enabled, just make sure jacks are set to unbalanced and phantom power is off. I say should work, rather than will work, because there are a lot of cables out there with hidden capacitors, resistors and cross connections, and the wiring of the Epic/Scarlet audio jack when set to unbalanced is still not clear to me. Bottom line: know how your cables are wired, and please RED, add a pinout diagram to the manual for the jack set to unbalanced.
    Senior Member Malvin Ng's Avatar
    Apr 2011
    Quote Originally Posted by Steve Wake View Post
    My least favorite topic regarding Scarlet/Epic.
    Here is a thread that contains all of my thoughts, and those of many others on this issue: http://www.reduser.net/forum/showthr...on-the-scarlet
    Update: Alpha 2.0.2 does enable phantom power.
    Bottom line:
    • Do not plug and pray. Know your jack, plug and mic power requirements!
    • The Sony stereo mic listed does not and will not ever work on Epic or Scarlet. Like most all consumer mics without an internal battery, it requires bias power - different from phantom power.
    • Same for the Olympus mono mic - it requires bias power.
    • It really would be nice if RED went ahead and started selling that button mic in the old linked thread above so people would stop plugging in bias powered consumer mics, mics made to be plugged into DSLR's, etc. and expecting them to work. I assume the RED prototype was a phantom powered button mic. If anyone knows of a button phantom-powered mic please let us all know!
    Agreed ... I wish RED would just sell the button mics they said they would be working on, it would really solve the audio issues most people have with the EPIC/Scarlet trying to get scratch audio ... but still no news about that yet...
    Dec 2009
    Hollywood, USA
    Plug in any lav, glue it on the front of the camera, and I expect it will give you the same sound as the button mike. Note that if phantom powering does not work, you'll need a dynamic lav. In my experience, this will not be great, even as scratch audio.
    marc wielage, csi colorist/post consultant daVinci Resolve Certified Trainer
    Oct 2007
    This is what you need.
    http://www.ambient.de/en/produkte/am...tiny-mike.html
    Its a great mic, Id just not mount it on the camera.
    Senior Member Ben Pluimer's Avatar
    Nov 2011
    Any idea if this would work?
    http://www.amazon.com/Mini-Microphon.../dp/B00277EMQ2
    Or modify this somehow, just chop the cable down.
    http://www.amazon.com/3-5-Computer-C.../dp/B001N0W2B6
    And one with a short flexible cable. (I'm gonna buy this one try it out)
    http://www.amazon.com/3-5mm-Flexible-Microphone-Laptop-Skype/dp/B002EQ6E9E
    Junior Member
    Nov 2011
    http://www.audio-technica.com.hk/ind...d=481&lang=eng
    Anyone tried this mono mic?..
    Thxthx
