From another thread, "Sensor Coverage on Scarlet" David Fuller has tested some s-16 lenses on Epic. Some work. Some won't even mount.
So as soon as possible we need to post a database of what s-16 lenses will cover 2K and 3K and mount without interference."I can tell you for sure that a Zeiss 11-110 S16 lens works great on an Epic. It covers more than 2k, but not quite 3k except maybe at the long end. At the narrowest point of its image circle, it covers a 16x9 frame that's 2400 pixels wide. That gives you resolution in the Alexa ballpark when down sampled to 1920x1080.
The 25mm and 16 mm Zeiss MK I superspeeds cover more. Very close to 3K, but not quite. The Bad news is that the 12mm and 9.5mm don't clear the OLPF. The Angineux 5.9mm also won't clear the OLPF on an Epic. "
