Thread: EF -> C-Mount Adapter + Crop Factor = Magic?
Results 1 to 6 of 6
  1. #1 EF -> C-Mount Adapter + Crop Factor = Magic?
    Jan 2008
    Grand Rapids
    So in absence of a RED C-Mount. Does anyone know of the flange distances jive enough that I can do a C-Mount to EF adapter, and bolt on some nice C Mount wides for use with my crop-factoring Scarlet at 2k or so?
    Apr 2010
    Portland, OR
    Good question! Anyone have an answer?!
    May 2007
    The “flange focal distance” is 17.52mm (0.69 inches). This distance is measured from the lens mounting plane (i.e. the rear surface of the lens which butts up against the camera) to the focal plane (i.e. the plane of the film or sensor). The C-Mount standard also defines the thread length as being 3.8mm.
    May 2007
    Maybe you would have more success if you designed a c-mount to replace the ef mount completely?
    Scarlet-X #2439
    Braunschweig, Germany
    Most C-mount wide lenses for 16mm won't cover Scarlet, even at 3K. 2K may work if you can get the flange distance right, but your images will be quite soft.
    On my other camera, a GH2 with a µFt sensor, a Kern Switar 10mm 1:1.6 is showing nearly a full circle instead of a rectangle…
    Regards,
    Uli
    My Red is called Vertov after a Russian avantgarde filmmaker, a pioneer in modern cinematography, a true revolutionary who later suffered under Stalin's bureaucracy.
    Senior Member Jacek Zakowicz's Avatar
    Jun 2008
    Quote Originally Posted by Cedric Akins View Post
    What he means is that a c-mount lens would end up ramming into the Epic OLFP way before you'd see focused image.
    Jacek Zakowicz, Optitek-dot-org, jacek2@optitek.org
    Professional Broadcast and Digital Cinema Equipment
