Click here to go to the first RED TEAM post in this thread.   Thread: Known EPIC issues/faults
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
  1. #11
    Senior Member Stephen Williams's Avatar
    Europe
    I had the touch screen freeze yesterday, rather than a reboot I just unplugged & re plugged. It's pretty stable, things change slightly build to build but nothing major. I would do a black calibration on any rental camera.
    Epic M owner
    Senior Member Justin Marx's Avatar
    Jul 2011
    Hollywood, FL
    Just to add some minor things:
    Stock RED battery plate + 2b-1b cable + RED bricks, for me will not produce a voltage readout, never has.. Many people have this same issue.. This is big because unless you press the button on the battery frequently, the camera will just shut itself off when the battery dies, no warning.. I know Deanan and the RED team are working in this, but be aware..
    Not a fault, but just more info/temporary issues to keep in mind:
    RED Bomb EVF and RED touchscreen can not operate at the same time (yet) but you can unplug and plug while camera is powered up..
    A Lift, gamma, and gain you set in Red Cine X can not be saved to camera (yet)
    You can not make toast with it (yet) but I'm sure that module will be coming soon..
    Like with any camera, whether brand new or 20 years old, test it before you get on set, or hire someone who has..
    EPIC-M 1261 - officially named "Take 2"
    Norway
    If you need audio, check that you have the right cables (minijack.)
    Only one sdi out. You have to be a bit a'cautioas as to what you put last and first in the chain, as some devices strip the signal (if you want audio, TC start/stop and such to float down the cable)
    No 1080 psf. No 720 p50 (yet)
    Sounds small, but make sure your other equipment is compatible.
    Make sure that the renter have all the neccessary cables + 1 each of TC, LCD, audio
    Enjoy the cam and make great images! (Not really a bug, just easy to forget)
    Life is good. So is RED...
    http://youtu.be/mhFB1CMzQBM
    http://bit.ly/mCwcoN
    Twitter: gunleik
    Europe
    Quote Originally Posted by Justin Marx View Post
    I had voltage readouts until last firmware upgrade, sure it will come back!
    Epic M owner
    Senior Member James Drake's Avatar
    Oct 2009
    Denver
    1) Be sure to do a black shading when switching frame rates
    2) High frame rate footage likes a LOT of light
    Otherwise, the thing is a workhorse. We've been shooting 14 hour days, no dropped frames, no problems!
    Epic-M #1169
    Production: www.jdfnet.com
    Camera: www.5kinsight.com
    Senior Member Julio Quintana's Avatar
    Austin, TX
    Quote Originally Posted by James Drake View Post
    Why do you recommend this? I never had to do that with my RED ONE. Have you noticed something different?
    Julio Quintana
    www.juliomquintana.com
    EPIC-X #560
    Canon Lens Package-
    -11-16mm f2.8
    -16-35mm f2.8
    -24mm f1.4
    -35mm f1.4
    -50mm f1.2
    -85mm f1.2
    Senior Member jimhare's Avatar
    Sep 2007
    Sydney Australia
    Anyone had a glitch that stopped a take, or are most of the glitches start up/standing by related? The R1 used to stop recording if there were Codec Faults/Audio Error etc.
    My next live shoot will be the first with Epics and I haven't heard a lot about issues with shooting long takes.
    Mine arrives tomorrow so will start some comprehensive tests.
    The good thing is a 12 second startup is a get out of jail free card. When the R1 used to stop during a take (hasn't happened for two years but in the early days was an issue) it would kill 2 minutes + from that angle, which caused problems back then.
    If anyone has any stories or advice about 70 minute takes on the Epic, would love to hear it!
    Jul 2011
    Hollywood, FL
    Hmm, never done one that long.. Honestly don't think I would risk it.. I'd cut when possible, give the fan at least a few seconds to let the little baby breath.. You would be quite sad if there was an issue with a 70 min take.. Good question though..
    Also if sound is not an issue, I'd have that baby cranking while rolling!
  9. #19 Straight out of the box...
    Hmmm,
    Good thread idea.
    No gotcha's to report at all my end though.
    Been shooting the EPIC-X out of the box since Sept.
    The first day felt, looked and worked as if the darn thing had been beamed in from the future.
    And a very distant one at that :-)
    My RED adventure began with build number 12? on Gibby's #8 R1 in Aug '07.
    Required a few tweaks to adapt the early builds to our applications.
    Such as our re-useable underwater cooling system that also made a great snack after shooting several hours.
    I will POST any challenges I encounter in the field as well as solutions as EPIC-X begins to travel with me around the planet underwater and in the air.
    We'll see...
    Senior Member Josh Beadle's Avatar
    Sep 2011
    SoCali
    Nice gear Ken!
    Josh
    Epic-M 1388 aka "Black Sheep"
    ATV FamFun
    It's not your camera's fault:
    http://www.youtube.com/watch?v=jJm2EGNIod0&feature=related
    "Your first 10,000 photographs are your worst"
    Henri Cartier-Bresson
