Thread: New PC NLE System - Anything Missing?
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    Apr 2009
    Singapore
    Hi, if you are looking towards also using this for color grading Jeff is correct, consider a BMD HD DeckLink Extreme 3D+ for the HD-SDI out to the monitor. When DaVinci Resolve for Win is released in Q1 2012 you can then add a second. third, fourth GPU. At IBC on our alpha Resolve on Win system we had 20+ nodes at HD with four GPU's.
    CS 5.5 works well with Resolve too using XML for round trip.
    Peter
    Quote Originally Posted by Barry Gregg View Post
    The HDMI to SDI is for color grading. My grading monitor is a Panasonic LH1700W.
    That's what I was thinking. You should question your friend on this decision -- it's not a bad decision, but you should be aware of what you are buying into. Some of this will depend on the software you intend to use. The Quadro 4000 is a poor performer compared to many lower-priced cards and there isn't an NLE software out there that utilizes any specific Quadro features to warrant the Quadro purchase. Some of the Quadro cards (the 4000 included) can output 10bit over DisplayPort and HDMI. And this is a valid reason to choose one of the new Quadro cards (4000, 5000 or 6000 model). Although, like I said above, not all software can enable or properly support the 10-bit output. You are also limited to resolutions and scanning frequencies supported by the card and/or various GUI modes available. You will gain much better results and better overall performance and compatibility by using a dedicated capture and monitoring card such as the Black Magic or AJA cards.
    Given that a Quadro 4000 sells for around $650 give or take and the BlackMagic converter is approximately $400, going the route of the GTX 580 will give you a much more powerful GPU at a lower price. The money you save there, along with the money saved by not buying the HDMI to SDI converter, will pay for the better portion of the above-mentioned BMD or AJA card.
    Storage is missing from the list, but it was intended. I don't know what Raid controller he had in mind. Good question. Thanks.
    Definitely something to look into. Many of the better motherboards have decent RAID controllers built in. The drawback to those is that they usually have rather poor management and usually nothing in the way of intelligent error handling or fault-tolerance. Some of the newer ones over the past couple years have RAID-5 and RAID-6 support, but I try to stay away from using them for the more advanced RAID setups for the reasons I just mentioned. For creating an onboard RAID-0 set, they're often a great solution.
    - Jeff Kilgroe
    Moderator Tom Lowe's Avatar
    Jan 2007
    Intel is about to ship the replacement to the 5520 here in about a week... Just sayin'
    a week? what is it? can you give me a link if you get a chance?
    if it's only a week away, i guess i should delay pulling the trigger on this new system.
    Hehe. Don't get too excited. The new chipsets are supposed to release to OEM's in the next week or so. That puts new motherboards at 30 to 60 days out. The new multi-CPU capable Sandy Bridge E-Series Xeons won't release until December. The EX Series SB Xeons are like January-ish...
    That's pretty much all we know at this point. If you need a system now, you need one now. Just saying that the 5520, while a solid performer, is about 3 years old now. yes, really. One of the longest-lived Intel chipsets ever. I have a hunch that its replacement will be relatively short-lived, but we'll see. I'm basing that on most of the reports circulating that it won't have Thunderbolt integrated and will still have a hybrid PCIe gen2 and gen3 setup, mostly like current Sandy Bridge desktop chipsets and the Cougar Point C200 series single-CPU Xeon chipsets have. Which means that Intel will probably replace them the following year with more solidified offerings...
    - Jeff Kilgroe
    Member Bruce Buck's Avatar
    Jan 2010
    San Antonio, TX
    Correct. For example, if you run any other 3D or other compositing programs, such as 3DS Max, Maya, Smoke, or 3D CAD applications, only Quadro cards are certified for use with those programs. The GeForce will "work", but you'll run into issues with the 3D programs. As far as 10-bit, doesn't CS5 support 10-bit?
    Also agree on upping the size of the SSD. Especially if you set your Media Cache to be on that drive. Premiere will fill that up fast. In fact I would actually avoid having your cache folder on an SSD.
    Senior Member Paul Ellington's Avatar
    Aug 2011
    New York City
    Sounds amazing, can you post transfer times and workflow?
    Jul 2007
    Marseille/France
    In CS5.5,for instance,you can only use the second port of a Nvidia card for monitoring and benefit of Red(Adobe)presets and Mercury hardware acceleration.With other I/O cards which you have to use the presets,monitoring is jerky.
    The quadro 4000 with the SDI daughter card is ideal for 10 bit monitoring through HDSDI and alone for 10 bit monitoring through Displayport(Dreamcolor) on PC in Premiere.
    The GTX serie is more powerfull and less expansive but only 8 bit.
    Since you monitor on a 8 bit display,a GTX with a DVI to HDSDI converter is ok...
    http://planb-red.com
    Red Epic camera rental
    Location caméra Red Epic
    Marseille
    Tom,
    I guess a sumnation of what Jeff is saying might be buy now on the system you spec'd.
    Think of it this way although the chipset is around 3 years old (minor iterations included) it is going
    to be very solid driver wise etc.
    By the time the new stuff comes out, kinks and bumps ironned out, it will be well into the summer fall.
    Prices are not going to drop that much at all; Intels really holding price points this cycle with what looks like
    new stuff actually coming in at higher price points this time and current stuff barely dropping.
    So all in all, pull the trigger is what I would do, because Jeff is right about the absence of Thunderbolt full
    PCI 3 etc.; this chipset etc. probably won't have a long shelf time.
    Persistence baby, persistence.
