This is a solution I cooked up for the last 3D epic feature I was on....take a look might solve some problems for a few of you.
http://steadi3d.com/2011/09/red-epic...th-aja-ki-pro/
It worked.....not without some hickups from time to time but since the epic doesn't make any "proxies" this is the best solution if you find yourself without the transcoding horsepower or redrockets.
Not to mention it gives you on set (2D) playback.....
we used Ki-pro mini's but it should also work with the larger version.
