Thread: Sun Time Lapse
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. #1 Sun Time Lapse
    Member Samuel Haskell's Avatar
    Sep 2009
    Los Angeles, Oxford, NYC, 日本
    I am trying to shoot a time lapse on the epic of the sun rising and going across the sky until about noon.
    What filters should I get/ what do I need to protect my camera/sensor.
    Also, what frame rate should I shoot at to get the smoothest image, what RC should I shoot at?
    Thank you
    Senior Member Christopher Barrett's Avatar
    Sep 2010
    Chicago
    This time of year that scene will take about 5 hours (in Chicago, where I am). How long do you want the clip to last? Let's use 5 seconds as an example...
    5(seconds) * 24 (fps playback) = 120 frames
    5 (hours of scene) = 300 minutes
    300 / 120 = 2.5 ... shoot a frame every 2 and a half minutes. You could also just shoot more and adjust the clip speed later to your liking.
    Plug in your own sun duration and you should be good.
    Filters? ND for sure. HDRx to boot for DR.
    My Too Sense...
    __________________
    I DP'd the hell out of that shit.
    The Website
    Banned
    Oct 2007
    Tasmania
    25 seconds at 24 fps is 600 frames; shot over 5 hours gives you one frame every 30 seconds. So, you will need about 12 - 14 stop ND when shooting at ISO 320, depending on your f stop and shutter.
    Senior Member Liam Hall's Avatar
    Nov 2007
    London/Worldwide
    Quote Originally Posted by Pawel Achtel View Post
    That won't work. If he's shooting from dawn to noon, he's in a wide shot. 14 stops of ND will end in extreme underexposure of everything except the glowing orb. HDR is his only hope. Do an exposure test the day before at noon - depending on the weather, that should be the brightest part of the day.
    I make stuff.
    www.liamhall.net
    Senior Member Radim Schreiber's Avatar
    Oct 2008
    Iowa, USA
    I believe the biggest issue you will have is change in exposure from day to night, more than 8 stops. How do you control exposure so you achieve smooth transition? You may choose to let the sunset go very dark, but that may not be very pleasing to the eye.
    Sep 2010
    Chicago
    This is why I always use my 5d2 for Timelapse... Set it up with aperture priority auto exposure and leave it alone while I'm shooting motion elsewhere with my Reds.
    __________________
    The Website
    Banned
    Oct 2007
    Tasmania
    Quote Originally Posted by Liam Hall View Post
    Why not? I routinely shoot 2s shutter with 10 stop ND at f/8. If you shoot 15-30s shutter, your ND would need to be around 14. Example:
    http://vimeo.com/29347608
    Banned
    Oct 2007
    Tasmania
    If you normally shoot 24fps with a 4 stop ND, when you slow down to 1 frame every 30 seconds, your exposure goes up by about 1000 times, which is about 10 stops. Thus, 10+4=14 stops ND.
    Sep 2010
    Chicago
    Not sure what you mean by that.... there's no reason you couldn't shoot at 1/48th (for example) regardless of the interval. Your shutter speed does not have to be relative to your FPS.
    __________________
    The Website
    Banned
    Oct 2007
    Tasmania
    Quote Originally Posted by Christopher Barrett View Post
    Sure, if you don't mind jerky footage and lack of motion blur.
