Click here to go to the first RED TEAM post in this thread.   Thread: Audio Cable for Epic X
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 40
  1. #21
    Jun 2009
    Central Florida
    Quote Originally Posted by Erich Ocean View Post
    It comes with a bolt-on rod that works with any 1/4-20 hole (there's some on the top of the Epic).
    Perfect. Thanks!
    Aug 2008
    The wiring diagram for the cable pictured works for a single channel balanced or unbalanced. That is the correct cable wiring for Epic and Scarlet. An unbalanced connection would use the tip/sleeve connections but omit the ring on the TRS. Pins 1 ground and 2 hot on the XLR. Balanced input uses all three.
    Member Jean Simenon's Avatar
    Nov 2011
    San Francisco
    That's good news. Would you have a picture of it mounted on Epic? Thank you!
    Nov 2011
    I tried these same cables at the office with a Sound Devices 442 and also with a Lectrosonics lavalier plugged directly into the Hosa adapter. I was able to get a decent signal, but experienced really loud handling noise if i even touched the Hosa adapter cable. It seemed like it would be unusable audio due to the possibility of that handling noise anytime the cable shakes just a little.
    Has anyone had similar experience? It was only a $10 adapter, I thought maybe it didn't have proper sheilding.
    Also, could not get a good headphone level - seemed very weak. In the quiet office, the headphone level was just loud enough for me to hear the sound, but not really strong enough to monitor or mix.
    Story Teller Brian Ferguson's Avatar
    Irvine, CA
    Quote Originally Posted by Mike Kushner View Post
    I mainly posted about this cable so people could see what the wiring was like. They are built to be inexpensive, I have had one fail, but they are easy to get. Have not heard any handling noise myself.
    Did you go into the menus to raise the headphone output? Have not had any headphone problems.
    Senior Member Antony M's Avatar
    Jul 2009
    Sussex, England & Sachsen, Germany
    Quote Originally Posted by Brian Ferguson View Post
    I have been through all the menus, but can't find anything for the headphone output.
    Can you tell me where in the menu system it is?
    Thanks.
    Senior Member Stephen Mick's Avatar
    Jun 2011
    Austin, Texas
    Your headphone output is the menu item that says Audio Output. That controls the volume that comes out of the headphone port.
    Jun 2011
    Austin, Texas
    Oh, and FYI…
    I picked up a pair of Guitar Center-branded ("Live Wire") XLR-Female to 3.5mm Mono cables, and they seem to work perfectly to take the signal from my MixPre-D to the Epic.
  9.   This is the last RED TEAM post in this thread.   #29
    Red Team Stuart English's Avatar
    Irvine, Ca
    Quote Originally Posted by Antony M View Post
    On the current release code, nothing that specifically says HEADPHONE, but go to SETTINGS / AUDIO _ VIDEO / AUDIO OUT
    Move all those sliders to -9dB ( - 1dB is also fine ) and you should hear audio now...
    Workflow Wizard
    Jul 2009
    Quote Originally Posted by Stuart English View Post
    Thank you Stuart.
