Click here to go to the first RED TEAM post in this thread.   Thread: Everything you wanted to know about the EPIC Canon Mount
Page 1 of 101 123451151 ... LastLast
Results 1 to 10 of 1002
  1.   Click here to go to the next RED TEAM post in this thread.
  #1 Everything you wanted to know about the EPIC Canon Mount
    I have received a ton of questions through email over the last couple weeks on the Canon mount. Thought a thread was fitting.
    First of all.. Let me introduce he first production Titanium Canon EOS mount that just came off the line today, along with the new lens caps:
    -These will start to ship to customers on September 9th.
    -Deposits will open on RED.COM in the store in the next couple days. Price for the smart Titanium Canon mount is $2000.
    - The Titanium mounts are all machined out of solid Titanium.
    -Current EPIC builds all support Iris control over the mount. An early AF build will be released around the time when the mounts ship. This will include basic touchscreen autofocus.
    -After release You don't need separate builds for different mounts.. AF support for Canon and Nikon etc. will all be integrated into the " normal " EPIC builds, so you can switch from PL to Canon mount to Nikon mount all with the same camera build.
    - Speaking of switching, it is a field safe procedure ( in a clean area ) and literally involves unscrewing 4 bolts and swapping mounts.. Then check back focus ( if needed )
    - The Canon lens mount is "SMART" which means it controls camera Iris, Image Stabilization, and Autofocus electronically, via the various control options with EPIC ( touch screen, side handle, REDMOTE )
    - A lot of people have emailed about the nature of Canon lenses sometimes being loose in their mounts on their DSLRs. We have added a locking ( as you can see in the photo above ) so you bayonet the lens into the mount as normal, and then rotate the locking to double secure the lens. No more rotation, no more wobble :)
    -All lens data available from the lens will be stored in the R3D metadata. There is on screen displays for iris stop, focal length ( including zooms ) and the current focus distance in inches or mm.
    -Here is a list of Canon lenses that have been programed into the mount/ Epic Brain. These still need to be characterized for fine-tuned autofocus as they all have different motor speeds etc., but they are and will be functional out of the gate when the Canon mount ships.
    Image Stabilization is functional on the entire stabilized lens lineup.
    Canon EF 16-35/2.8L II USM
    Canon EF 24-70/2.8L USM
    Canon EF 70-200/2.8L IS USM
    Canon EF 70-200/2.8L IS II USM
    Canon EF 35/1.4L USM
    Canon EF 50/1.2L USM
    Canon EF 85/1.2L II USM
    Canon EF 70-200mm 1:4 L USM
    Canon 24-105mm 1:4 L IS USM
    Canon 17-40mm 1:4 L USM
    Canon EF 70-300mm 1:4.5 - 5.6 DO IS USM
    Canon EF 100-400mm 1:4.5 - 5.6 IS USM
    Canon EF 24mm f/2.8
    Canon EF 35mm f/2
    Canon EF 50mm f/1.4 USM
    Canon EF-S 10-22/3.5-4.5 USM AF (APS-C)
    Canon EF-S 17-55/2.8 IS USM AF (APS-C)
    Canon EF-S 60/2.8 Macro USM AF (APS-C)
    Canon EF 200/2.8L II USM AF
    Canon EF 28-300mm 1:3.5 - 5.6 L IS USM
    Canon EF 180/3.5L Macro USM AF
    Canon EF 300/2.8L IS USM AF
    Canon EF 135/2.0L USM AF
    Canon EF 300/4.0L IS USM AF
    Canon EF 400/5.6L USM AF
    Canon EF 100/2.8L Macro IS USM AF
    Canon EF 400/2.8L IS USM AF
    Canon EF 35/1.4L USM AF
    Canon EF 50/1.2L USM AF
    Canon EF 500/4.0L IS USM AF
    Canon EF 600/4.0L IS USM AF
    Canon EF 85/1.8 USM AF
    Canon EF 100/2.0 USM AF
    Canon EF 135/2.8 AF SF (Soft Focus)
    Canon EF 200/2.0L IS USM AF
    Canon EF 400/4.0DO IS USM AF
    Canon EF 14/2.8L II USM AF
    Canon EF 24/1.4L II USM AF
    Canon EF 15/2.8 Fisheye AF
    Canon EF 20/2.8 USM AF
    Canon EF 28/1.8 USM AF
    Canon EF 28/2.8 AF
    Canon EF 50/2.5 Compact-Macro AF
    Canon EF-S 18-200mm f/3.5-5.6 IS
    Canon 50/1.4 EX DG HSM AF
    Canon 85/1.4 EX DG HSM AF
    Canon 20/1.8 EX DG ASP RF AF
    Canon 24/1.8 EX DG ASP Macro AF
    Canon 28/1.8 EX DG ASP Macro AF
    + a few 3rd party lenses. More lenses being added weekly.
    If your lens is not on the list, it's ok, you still will get rudimentary support, such as IRIS control and Stabilization if the lens has it.
    I will add things to this list as questions come up.. so ask away.
    First off. All of this is very cool!
    Congratulations
    OK. I'm changing my question.
    Quote Originally Posted by Jarred Land View Post
    I think that this is a very important and powerful feature.
    Is the metadata accessed through RC-X?
    Can an XML of the metadata be exported?
    Thanks,
    David
    "A revolution is not a bed of roses.
    A revolution is a struggle between the future and the past." – Fidel Castro
    Member John Heaney's Avatar
    Sep 2010
    Manchester, UK
    Superb Stuff! Well done YET again.
    Senior Member Mike Zinner's Avatar
    Vienna
    Excellent information here. Thanks for answering all the open questions!
    Apr 2009
    London
    Fantastic, can't wait.
    Will the touch screen autofocus be working right out the gate?
    Thanks,
    Richard
    Jan 2008
    Very cool indeed.
    Mark Toia
    www.toia.com
    www.zoomfilmtv.com.au
    Senior Member luigivaltulini's Avatar
    Oct 2009
    Switzerland- LUGANO
    YEEEEEE VEEEEEry Coooollll ;)
    thanks RED TEAM ;)
    Senior Member Detlev Eller's Avatar
    Mar 2008
    Berlin, Germany
    impressive (!)
  9. #9 Wow
    Senior Member Tom Gleeson's Avatar
    Nov 2007
    Sydney
    I believe this ability of a cinema/television camera to take advantage of high quality lightweight electronic still lenses can be a game changer. Opening up a whole range of new possibilities to doco and TV production. Certainly won't be replacing quality PL glass on drama and high end TVC but for alot of production this will be the way to go. I'll be buying one.
    I understand the value of AF in finding focus and possibly tracking a subject just as you would on a DSLR but as the system stands can you control the lens with an "external" control as you would with a remote follow focus? Will this require a third party device or is this what the Redmote Pro does?
    Tom Gleeson
    Counting the seconds .....
