Thread: Remote start schematic for EPIC
Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1 Remote start schematic for EPIC
    REDuser Sponsor Andy Jarosz's Avatar
    May 2009
    Chicago
    Maybe it's just me, but there are three things about this circuit found in the EPIC operation guide that strike me as overlooked/sloppy...
    First of all, that's an LED in the middle. It took me a little while to figure out that it's not just a seemingly randomly placed diode with arrows coming out of it. Correct me if I'm wrong, but I conversed with a friend of mine about it and that's what he got out of it too.
    Second, it's supposedly a Schmitt trigger. Again correct me if I'm wrong...but this is just a decoupled 3.3v.
    Third, it's going out to a LEMO connector, not a BNC, correct?
    I could be totally wrong about everything here, but this is just what I got out of it.
    AC and owner of MadlyFins, LLC
    Chicago, IL
    708.420.2639
    andy@andyfilms.net
    www.madlyfins.com
    Feb 2010
    L.A. penal colony
    The skeematik makes sense to me. The symbol for the LED is correct.....a bit exaggerated from an artistic standpoint, but stil correct. As for the BNC, well I suppose LEMO pinout would be more useful.
    Nov 2007
    RED makes a breakout cable for the camera control port with BNC connections, thus the BNC connector noted.
    Mitch Gross
    Applications Specialist
    AbelCine
    mitch@abelcine.com
    212-462-0100
    Jan 2007
    Mitch is correct. With this cable, you connect your remote start / stop to the white BNC, in Epic setup menu setting, set the camera in to GPIO and it works like a charm. We made one based off of the diagram and works like a charm.
    IATSE Local 600 DIT
    www.FreehillProductions.com/
    Has anyone had success making a remote start stop cable for the epic going straight into the 4 pin Lemo? I would love to know the correct pin info if available.
    Brian
    Jul 2007
    Marseille/France
    Page 138 of the Epic operation guide.
    http://planb-red.com
    Red Epic camera rental
    Location caméra Red Epic
    Marseille
    Junior Member
    Feb 2008
    Quote Originally Posted by brian mcclatchy View Post
    Brian
    Brian,
    The connector's (Lemo 00-series) pinout remains the same. The GPI trigger that was used on Red One cannot be used with EPIC, unless you have a PRO I/O which is claimed to be equipped with similar connector (Lemo's 0B-series) and then you could short pins 1 and 2. (EDIT: Please do not short pins without referring to the product's manual. You may cause a lot of damage.)
    great - thanks for the info. we are working on a solution and will post what we come up with!
    Senior Member Manuel Wenger's Avatar
    May 2007
    Hohenkammer, Germany (near Munich)
    i just ordered the parts shown in the diagram and will get them tomorrow.
    I´ll build a small box housing 3 x AAA batteries supplying 4,5V with a BNC Connector.
    I ordered the Sync Breakout Cable, so i can use any length of BNC Cable i need to remote start/Stop the camera.
    I´ve a car shooting coming up where the Epic will go on a car with a crane, so we need to remote start/stop the camera since i think the Redmote won´t ship yet, and even then, our last expericenes with Redmote where not good with distances longer than 6-9ft.
    insane4frame GmbH & Co. KG
    Munich / Germany - Production & Post Production
    Junior Member
    Apr 2009
    UK
    You probably worked all this out already, but the schmitt trigger is in the EPIC itself ! You could simply the schematic for sure- the cap is presumably just to help deal with a dodgy cable connection and to protect from ridiculously big power supply ripples... The LED (and its current-limiting resistor) is of course optional. Something which might not be obvious to a beginner- it's absolutely crucial that you connect your power supply's GND to the GND on the BNC or Lemo.
    Kris
