Click here to go to the first RED TEAM post in this thread.   Thread: Laforet + EPIC + Canon Mount + 600mm
Page 13 of 16 FirstFirst ... 3910111213141516 LastLast
Results 121 to 130 of 158
  1. #121
    Senior Member James Brundige's Avatar
    Feb 2008
    Snowmass, Colorado
    Some folks are very excited about the IS. You can't use it with moving images or a non-locked-off camera.
    Senior Member Shawn Nelson's Avatar
    Portland, OR
    Quote Originally Posted by Jarred Land View Post
    Wont be :( will follow by about 2 weeks.
    I want one! :-)
    "Only those who attempt the absurd will achieve the impossible." -MC Escher
    Quote Originally Posted by Douglas Learner View Post
    According to Vincent's notes on his Vimeo page it's more than 3400mm, shot at 4K and 120fps: http://vimeo.com/27212799 Amazing.
    Still surprised no one asks about the 3400mm claim, to get the same Field of View on a 24x36mm camera as an Epic X in FF with a 1200mm one would need around 1530mm on that 24x36mm camera.......
    Mar 2009
    I'm actually not getting that math, either. Perhaps someone could enlighten me?
    Code:
    EPIC Sensor @ 4K = 22.12mm wide
    35mm = 36mm wide
    36 ÷ 22.12 = ~1.6275x crop factor
    600mm lens x 2x = 1200mm
    1200mm x 1.6275 = 1953mm
    It seems to me that in order to get to 3400mm FOV, the sensor would have to be only about 12.70mm wide - or somewhere around 2.3K.
    Code:
    3400mm ÷ 1200mm = 2.833x crop factor
    36mm ÷ 2.833 = ~12.70mm
    Anyone?
    Senior Member Mathias Erichsen's Avatar
    Nov 2008
    Oslo, Norway
    Quote Originally Posted by James Brundige View Post
    What? I have used IS with great success when filming hand held with dslr´s... Is EPIC different in this regard?
    Nov 2009
    Regarding IS - I think some people hate it some people love it. It will resist your pans and tilts in a weird way - at least to me...
    Is there any issue using dumb Eos mount lenses like samyang 8mm or nikkor with Eos adapter?
    Cheers!
    Dan
    Senior Member Sanjin Jukic's Avatar
    Vienna, Austria
    Quote Originally Posted by Michael Olsen View Post
    Code:
    35mm = 36mm wide
    Code:
    Anyone?
    For the math maybe it could be better to use an image circle that is measured at least by size of the image frame diagonal because it should be more accurate approach.
    "Basically all lenses produce a circular image field and the diameter of that circle has to be larger than the diagonal of the frame, otherwise the corners of the image will be dark."
    LINK>>>
    FF35mm
    Now call Pythagorean theorem a² + b² = c²
    (36x36)+(24x24)=1872
    √1872=43.2666… or ∼43.27
    Image circle of FF35mm is 43.27mm.
    EPIC 5K
    (27.7x27.7)+(14.6x14.6)=980.45
    √980.45=31.312 or ∼31.31
    Image circle of EPIC 5K is 31.31mm.
    Now 43.27 DIVIDE (÷) with 31.31 and you get 1.381 or approximately (∼) 1.4x crop factor.
    So Epic has approximately 1.4x (or exactly 1.38x) crop factor related to FF35mm format.
    Again to illustrate that difference between FF35mm and EPIC 5K with this picture:
    Shot on Leica M9 with Summilux 35mm f/1.4 ASPH (additional text and graphics by SJ)
    Download the full res image here>>>
    "There is no point in having sharp images when you've fuzzy ideas."
    Jean-Luc Godard.
    Dynamic range is, after all, the measurement between well saturation (photosite blowout) and noise floor.
    Thom Hogan
    500px >>>
    Twitter >>>
    Facebook >>>
    Vimeo >>>
    Jan 2007
    $2k will hurt for Canon lenses. I was expecting a little lower, like near $1k.
    I don't mind spending for a titanium PL, but for Canon I might go with saving some money.
    Then again there are benefits... mhhh... And you need both if you want to rent more.
    Well, can't complain. ANY 10-second-interchangeable Canon mount on Epic is worth the price!
    Writer - Director
    Crowing Lakes.com
    Senior Member Vince Doran's Avatar
    Jun 2009
    Australia
    Quote Originally Posted by Sanjin Jukic View Post
    1200 x 1.4 = 1680mm?, I'm confused now. Surely someone knows the exact answer on this.......RED?
    Fathom Productions
  10. #130 if AF ever manages...
    May 2007
    ... to keep a subject moving directly towards you in focus when using a big telephoto... that would be a wildlife cinematographer's dream at times... Doubt it, though... we'll have to keep zooming down for quite a while to achieve that, I fear.
    Oh, Jarred, how is the sigmonster doing on Epic ? A swissknife to me...
