I use still glass all the time, mostly working alone, but occasionally with an AC. Focus by eye. Mount and mark a follow focus if there's a move. Not for big crews with 5 people on the camera, but I make docs, and the weight and image quality are great. If you've got a big budget, rent what you need.
Horses for courses, the Optimos are a proven design that can take the rigors of professional shows and seasoned ACs, they have excellent mechanics, focus marks and are optically superb, although the Nikon primes are probably a bit sharper. They both out resolve the Red One and Epic sensor so it's not an issue. As for color the Nikkors have a neutral/primary color bias while the Optimos have a slight warm/yellow bias but not as much as Cookes.
Hi Evin
I have just brought a set of Optimo Rouge zooms. However I was thinking of getting the Nikon G lenses as well for low light as I shoot a lot on Phantom Flexes and Golds. I have 2 issues:
1: How difficult is it for an AC to pull focus on them
2: Using the Prolock Nikon adaptor on a PL mount camera, how does this effect the Bokeh of the lens? Does the Nikon G stay wide open and there is a manual iris in the adaptor?
Many thanks
Robin Horn
2:
The prolock is not an adapter but a replacement mount for the Red One.
It does not have any optic to affect the Bokeh. As for focus pulling, using the Redmote pro it will be similar to a Preston or C-motion.
These options will of course not be available on the Phantoms.
FWIW Birger makes an electronic (focus and iris) Canon EF mount for the Phantom Flex (we will probably use it on a housing we are in the middle of making now - although it will also have provision for PL lenses as well) And of course Nikons work on the Canon mount in manual mode. As Evin says, because Canon has a shorter Flange focal depth you don't need an optic when using Nikon on Canon - just a thin mechanical adapter.
Actually the ProLock will work on Phantom with an adapter part I made.
FYI I'm just about done with the prototype ProLock for Epic as well...
Sorry for (slightly ) derailing the thread but I felt that corrections were needed and ProLock is essential at this time for use of Nikon lenses with motion cameras.
