Is 5k FF (full frame) resolution 5120 (h) x 2700 (v)? If so, it is not very far from 16x9 aspect ratio. Perhaps it can be masked out when shooting, and than cropped precisely in the post. Composition is everything.
16x9 is 4800x2700. I shoot 5K FF with the 16x9 guide enabled so that I can crop in post. Works really well for 3D because it gives you room on the sides to adjust in post.
I apologize if this has been asked, but I do not see this question.
Is playback coming anytime soon to the Epic?
I LOVED using it, but really wished I had playback...
Last night:
http://reduser.net/forum/showthread....ht=#post816591
Yesterday, 11:32 PM
Playback is coming soon..." Jarred
There was noise issue in early EPIC footage that was uploaded to internet. It was some short night footage of a guy walking around and it had some wierd non moving noise in it. Was this issue solved?
Simple question: is it possible to use the Ethernet connexion on the EPIC to transfer the .R3D rushes once recorded on the SSD (in case a RedStation is unavailable), or is it only for remote control / proxies / firmware updates? Thank you!
Is there going to be a fix for the OLPF-Flare Issue?
The corresponding thread was closed (not sure why, maybe the discussion heated up a little bit too much) -> http://reduser.net/forum/showthread....TREAK-FLARING/
