Click here to go to the first RED TEAM post in this thread.   Thread: Epic Q&A
Page 27 of 31 FirstFirst ... 17232425262728293031 LastLast
Results 261 to 270 of 307
  1. #261
    Quote Originally Posted by ericyoung View Post
    Haven't had time to do an exhaustive search, but is there a grid of Epic's current maximum varispeed framerates versus redcode setting and resolution/aspect ratio with the different SSDs anywhere? Doesn't seem to be one in the ops manual like the Red One had.
    And to echo Dustin above, would especially like to match Red One's 4K, 3K and 2K 16:9 FOV framing modes - what framerates can we get with those at Redcode 36 equivalent compression?
    Also, being in PAL land, very interested in framerates at multiples of 25 for those flicker, rolling bar issues with 50Hz location practical lighting.
    Thanks!
    Thanks John, but I don't have an Epic to play with, and the manual doesn't seem to cover my question directly.
    What I would like is to choose a FOV, resolution, aspect ratio, redcode to match a Red MX at 4K, 3K and 2K 16:9, and then know what's the maximum framerate (multiple of 25) at that setting.
    The Red One operation manual has a handy table covering varispeed options at various resolutions, redcodes etc.
    Bump
    Director/Digital Camera Operator/2nd AC/DIT/Data Manager
    London, UK.
    Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.
    Quote Originally Posted by Dustin Bowlin View Post
    Hi all,
    Just flipping through settings on the EPIC M today. Is there any chance in future firmware releases that we could see framing modes that mirror the MX based cameras? For matching purposes, it would be a nice feature for a 2 camera setup.
    thanks,
    Dustin Bowlin
    4k HD mode is the closest to what you are asking for.
    2010 REEL
    Lucky #13 Epic #00157
    Senior Member Radim Schreiber's Avatar
    Oct 2008
    Iowa, USA
    Is there a plan for firmware update to offer 16x9 5k or 4.5k?
    Senior Member Curran Giddens's Avatar
    Jan 2007
    Berkshire County, Massachusetts
    Really hoping for a 3K at 240 fps option too. Or however many fps we can get at 3K.
    2K at 2.4:1 is not quite high enough res...
    http://www.SolarSystemStudio.com/
    EPIC-M #508, EPIC-X #124
    + 1
    Mark Pugh LA,NYC, and AUS.
    www.markpughfilms.com
    Several EPICs...
    Does 4K 2:1 enable?
    Regards
    Chan Chi Ying
    DP HK
    Chan Chi Ying
    5KFF is essentially 16x9 with the tiniest of crops. Has been fine for us for any 16x9 needs. We typically shoot 2:1 and frame fro 16x9 to have a little extra breathing room if needed.
    Jason
    Jason Diamond
    The Diamond Bros.
    @jasondiamond
    EPIC-M 512 & EPIC-X 1423 Ti PL and Canon Mounts.
    Leica-R Duclos Cinemod 19,24,28,35,50,80,100
    REDRockets and Sonnet TBolt Rigs Avail.
    Avail NYC and anywhere trains, planes and automobiles go.
    4KHD is the only 4K option right now. It's the same QuadHD as the REDOne in direct Quad scale from 1080.
    Jason
    Jason Diamond
    The Diamond Bros.
    @jasondiamond
    Senior Member John Marchant's Avatar
    May 2010
    Normandy, England
    Thanks!
    Just compiled this, which you may find handy ;) http://reduser.net/forum/showthread.php?62183
    Epic Monochrome UK/EU Rental - rentmonochro.me
    Check out our showreel or talk to us @kippertieltd
    EPIC-M #549 EPIC-M MONOCHROME #1649 EPIC-X #3038
    KipperTie
    creative media for business
    Jan 2010
    16:9 5K would be really nice for work that sometimes does't have the post workflow for extensive re-framing. Sometimes you don't use the rawpower of red, and shoot something and render it directly to 16:9 Proress 422 1920x1080, and the end product finishes in that format.so a true 16:9 format would be good to have.
