Thread: Problems with stability
Results 1 to 4 of 4
  1. #1 Problems with stability
    Senior Member Frank Weeks's Avatar
    Johnson City, TN
    First of all allow me to say that I applaud The Foundry and their investment in the Red workflow. I have been excited about this program since it was announced on reducer over a year ago. The problem is it had been very unstable for me from the beginning and with the newest build it will crash when opening.
    I have early 2008 mac pro , 12 gigs ram
    NVIDIA GeForce GTX 285 slot 1
    Red Rocket slot 2
    Blackmagic DECKLINK HD EXTREME 3D PLUS slot 3
    It was designed primarily for DaVinci which preforms flawlessly. Storm has at times performed well but has been very inconsistent and now fails to function at all. I really want this program to succeed but it needs help. FXPHD has taught me the Storm basics but I am at a loss to explain the instability. Suggestions welcomed.
    Frank Weeks
    www.digitalcinemasouth.com
    Epic-X and Red One MX
    REDuser Sponsor
    Nov 2010
    Hi Frank, sorry to hear that you are experiencing issues. Is it the Beta 10 build that fails for you on start up? At which point does it fail? i.e. Do you see the license window or splash screen before it fails? Or do you get as far as the Workspace and then fails? Also does the Beta 8 build still run for you?
    Can you try the following:
    In Finder go to 'Go' -> 'Utilities' -> 'Terminal'
    In the Terminal type the following (assuming Beta 10) pressing enter after each command:
    cd /Applications/Storm1.0v1b10/Storm1.0v1b10.app/
    ./Storm1.0v1b10 -debug="Default"
    ...after it quits, zip up the following folder and send it to us:
    <user>/Library/Application Support/TheFoundry/Storm/MTTF
    many thanks,
    Dan
    Johnson City, TN
    Quote Originally Posted by Dan A View Post
    many thanks,
    Dan
    I could see the license window. reinstalled 8, same results.
    Terminal results
    Last login: Sun Feb 27 20:18:52 on ttys000
    frank-weekss-mac-pro:~ Videodisc$ cd /Applications/Storm1.0v1b10/Storm1.0v1b10.app/
    frank-weekss-mac-pro:Storm1.0v1b10.app Videodisc$
    frank-weekss-mac-pro:Storm1.0v1b10.app Videodisc$ ./Storm1.0v1b10 -debug="Default"
    [Default] : Codec library init
    [Default] : Red R3DSDK Version 3.2
    [Default] : Total Supported Formats : 3
    [Default] : Setting up timer
    [Default] : Done - Engine Init
    Object::connect: No such slot Foundry::Storm::UI::ApplicationController::project AboutToBeRemoved( Media::Project* )
    There was no MTTF file or folder. It was RLM which included Foundry.lic and license.log
    Frank Weeks
    REDuser Sponsor
    Nov 2010
    Quote Originally Posted by Frank Weeks View Post
    Hi Frank, that should be a different path i.e.:
    <root>/Library/Application Support/TheFoundry/RLM
    The one we need is under your user i.e.:
    It's just that there's a Library folder for each user so it's easy to get the wrong one.
    thanks,
    Dan
