Thread: Corrupt R3D Files?
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1 Corrupt R3D Files?
    Hey Everyone,
    I was called in by a friend to take a look at some R3Ds that he is having problems with from a shoot last week. They seem to be an issue that I have never encountered before. I thought I would run it by you guys to see if you had any ideas as to how to salvage the files.
    The Issue:
    There are a total of 5 takes that have this issue. The clip looks to load fine into RCX. It will begin to play, but at a certain point the playback will freeze, but the cursor will continue to move. This locks up the program and you are not able to change clips in the viewer until you restart. If you close the program to restart it a crash report will pop up. It looks to happen at a certain point for each clips. However, during recording there was no report of dropped frames.
    If you export the file it has had varied result. Once it said there was an error. Other times it will complete, but then if you look at the playback in QT it will play fine for a while.. Then it will hit a point where it begins to replay a 1-2 second part of the clip, and this will continue for the length of the QT file. I've tried all RED programs and had similar results.
    The Details:
    The files were recorded to RED 16GB CF cards on an MX RedOne. I was told by the data manager that the cards were dumped and verified using R3D Data Manager, however I can not verify this. There was a total of 40 rolls shot on the camera over the shoot and only 5 total clips seem to exhibit the issue. The troubled clips came from rolls that also had clips that work fine. All of the troubled takes have multiple R3Ds making up the take, as they are rather long shots. However, there are plenty of takes that are the same length or longer that work fine.
    I'd appreciate any help that you could provide. I'd happily post the R3D files, but they are far too big to get up... Let me know if you have ever experienced or heard of this problem and happen to have a solution.
    Thanks for any help!
    Best,
    Tanner
    Mar 2009
    Burbank, Ca
    Quote Originally Posted by Tanner Field View Post
    Problem is: Bad on-set data management
    Solution is: Good on-set data management
    Quote Originally Posted by joe hedge View Post
    Helpful..
    Helpful..
    Unfortunately his assessment seems pretty spot on to me. Bad cf reader possibly, but seems like there was a lack of visual verification going on. Do the QT proxies play?
    Tim
    Local 600 DIT
    My Personal Portfolio:
    www.sutherlandprojects.com
    Feb 2007
    Tim nailed it. Bad CF reader corrupted the file. I had this happen and R3D manager caught the bad files before i wiped the card, re imported from the original from another card reader and all was fine.
    If you are running a card reader hard sometimes they overheat and data gets corrupted.
    Paul Hazlett
    Philadelphia Red #1350
    "Cheesesteak" EPIC-X #000257
    "Gertrude" Scarlet-X #000128
    phaz@verizon.net
    Thanks guys... That was my fear as well. The QT proxies suffer the same issue. I appreciate the confirmation. Off to relay the bad news.
    Tanner,
    If R3D Data Manager was used you should have the md5 checksums with the files. If you don't have the checksums they most likely turned them off to speed up R3D DM, which is stupid. If you do have checksums, then R3D DM failed.
    Dusty
    Dusty,
    Thank you for the information. I was given a separate drive with just the troubled files, but I'll take that information back to the producers and have them check the drives. Again, I really appreciate the support and the info.
    Best,
    Tanner
    I have exactly the same issue than you, not on the compact flash but on the hard drive.
    Usually, they do two time the file transfer, to have 2 master copy. This day, I don't know why, they did it only once. If you don't look very close, you don't see the problem when you are on the set. All seems fine, the quicktime plays. They did not either have the RedRocket mobile this day.
    Now, when I try to conform to Prores, RedCine crash or everyfile are black. If i conform the file one by one, sometime, I get a prores with these kind of drop (green or white half screen).
    Here is my question :
    What is the more robust software able to conform and save what we can, even with drops ?
    Is it more safe to use R3D software Data Manager or to do the copy twice, on 2 separate hard drive ? Or do you do both ?
    Olivier
    Hey Everyone,
    The Issue:
    The Details:
    Best,
    Tanner
    #MX2070
    Paris
    The frenchie doc
  10. #10 Prepare yourself for some fix-it time.
    Junior Member
    Nov 2010
    I got bit hard by this bug on my current Red project. Like you, it was some but not all of the clips. It turned out it was not only corrupt frames (which would turn any viewer green or grey or whatever) but missing (dropped) frames as well, which would hard crash any application I worked with.
    With the help of the attentive Red support team, I was able to at least get around the corrupt and missing frames. After identifying all of the corrupt clips (by playing each clip end to end in RCX and waiting for either a crash or other series of freak outs) I pulled those clips out of the data set in to their own "Corrupt Files" folder to stay organized. Then, I used RCX on those segregated clips to render out a lores tiff sequence using redline (frame only mode) using the instructions the helpful people at Red gave me, make sure to turn off handles everywhere.
    I would then take the image sequence in to Adobe Bridge to scroll through the myriad of frames to see which frames were bad. I used Bridge as I found this easiest on the eyes, you can use what finder or whatever you want. Bad frames showed up all black or with some digital garbage, but mostly black/blank.
    I then viewed the image sequences in Motion's browser, which showed me which frames were actually missing, if any. I used Motion because it was easy and did what I need. Other applications might be able to identify missing frames out of image sequences as well. The Motion method was super easy and quick.
    I then used RCX and the "R3D Trim" option to create new R3Ds around the bad/missing frames by frame number. Some of the clips I had to break up in to 5 new R3Ds to get around all the goofiness. It was a shame that the information was gone, but I was able to at least get to the offline edit to make proxy files. I put those fixed R3Ds back in to the good data set and left the corrupt R3Ds separated from the rest of the pack. The online process of one of the spots from that data set has been smooth so far through color correction. Getting all those files fixed/proxied took the better part of 5 days and nights. Prepare accordingly.
    Contrary to what flies around this website, this is was not due to file mismanagement/handling, the files were bad on the CF cards themselves as I was able to have a few of them sent to me across the country from the rental house before they were sent back out on another gig. There is a good reason that Red CF cards are going the way of the dodo, I'd imagine. It is straight up silly not to have a write protect switch on a professional medium, but I am starting to digress.
    Jeremy
