Click here to go to the first RED TEAM post in this thread.   Thread: M8 (aka 008)...
Page 10 of 15 FirstFirst ... 67891011121314 ... LastLast
Results 91 to 100 of 150
  1. #91
    Senior Member Shawn Nelson's Avatar
    Portland, OR
    Quote Originally Posted by Jannard View Post
    The only advantage to more bit rate is less compression artifacts, which is not very significant between REDCODE 42 (about 7.5:1) and normal EPIC compression around 5:1).
    ANy pickup in DR would mostly be based on a less noisy image due to more efficient boards... there is some but I wouldn't expect a big pickup native. Big pickup is HDRx™.
    Jim
    Good info! Will I be able to record 7.5:1 on Epic? I saw so little difference from RC28->RC36->RC42 on Red MX that I think 7.5:1 is all I'll need on Epic, I dont see why anyone would want 5:1 (much less 3:1) unless you massive detail infinity focused landscapes, greenscreen or fx plates.
    "Only those who attempt the absurd will achieve the impossible." -MC Escher
    Moderator Häakon's Avatar
    Los Angeles, CA
    Quote Originally Posted by Shawn Nelson View Post
    I think the intent is to have a wide variety of compression choices when Epic is ready for prime time.
    Senior Member KETCH ROSSi's Avatar
    Jan 2007
    ITALY
    Quote Originally Posted by Mark L. Pederson View Post
    Been rather busy. Lots of stuff to share very, very soon.
    FYI - BOND is headed to Milan on Monday. Since you are running around in the desert - I figured someone needed to shoot some Italian fashion in 5K
    He he, goo call Mark, yeah M8 was invited, but She is been pre-bucked in the US, so I'm happy that you are going, enjoy it ;)
    Quote Originally Posted by Steve Gibby View Post
    Hmm...OK Ketch, we tricked Mark into leaving town! Nows our opening to invade New York and shoot our 5K Big Apple footage
    He he, in deed Steve, we do have two shoots in NY, but was hopping to meet up with Mark @ OffHollywood, I guess next time ;)
    KETCH ROSSi | EPIC-M DRAGON M8
    Producer | Director | DoP |
    *CinePhotographer
    __________________________________________________
    *Registered Trademark of RED DIGITAL CINEMA
    Oct 2008
    Gorham, Maine
    Quote Originally Posted by KETCH ROSSI View Post
    After seeing Mark's Aerial frame, I was kind of hoping you guys would get into some kind of one-up contest. You know, "My Zion shot is better than your urban canyon..." "Oh yeah? My Italy shot is better than your snow..." the footage would be spectacular, and you'd hear the rest of us cheering at every new frame.
    I'm loving every shot you guys have put out there. The detail and DR is just taking my breath away. I know this has been a huge amount of work for you all. Thank you for sharing your time with us.
    David Fuller
    AirStream Pictures
    RED ONE #172MX
    EPIC-M #1053
    Jan 2007
    ITALY
    Quote Originally Posted by D Fuller View Post
    He he, no contests here, we love each other, but we will shoot Epic M8 till either the camera or We, DROP!!
    Trust me when I say that this next 8 Shoots coming up for EPIC M8 will be something not to miss ;)
    *CinePhotographer
    Senior Member Mike 'Fireman' Ross's Avatar
    Jan 2011
    Wellington New Zealand
    Ha ha... Priceless Post!!
    Thanks Mike ;)
    Well, I've just done a deal to lease/purchase an un-executed R1... so hopefully a bit later this year when Stage 3 starts I'll be opening my own box ;-)
    I decided the numbers added up for me and it made more sense going EPIC than Scarlet :-)
    Mike
    'No greater love hath a man than he lay down his life for his brother.
    Not for millions, not for glory, not for fame.
    For one person, in the dark, where no one will ever know or see.'
    RED SCARLET-X #513, 'Hekla'
    RED EPIC-X #2229, 'Katla'
    RED ONE MX #10066, 'Askja'
    Senior Member Greg Voevodsky's Avatar
    Silicon Valley, CA
    I noticed on the video, even in a room, the fan noise - until you hit record - was a bit loud. So, Im wondering what if one is shooting in the Bahamas in 100 degrees for 1 hour with no or little breaks... am I gonna fry the camera?
    Since, I'm really looking at the Scarlet, which should be cooler literally with a smaller chip - less heat... Should I worry about shooting on 100 degree beaches for an hour or so? My Nikon melted... it wasn't working - it over exposed everything even though I was on manual trying to fix it and my EX-1 seemed to add a ton noise due to the temp.
    I want to buy an Scarlet, but will it fry shooting in 100+ degrees for hours at a time?
    I'm sure if Epic will, Scarlet will... A few more questions... will the camera shut off before it fries like a humidity indicator - which happens in the tropics?
    I'm very nervous about frying my new RED Scarlet, so will it protect itself from heat and humidity, or do I need a cold pack. Thanks.
    Lastly how long do the grip only batteries last in the scarlet shooting 2k at 30fps?
  #98
    Red Leader Jannard's Avatar
    Quote Originally Posted by Greg Voevodsky View Post
    These cameras work as well as any digital camera in the heat... and much better than DSLRs which are not really made for motion. If you want to shoot a 5K silent one hour take in 100 degrees... you probably will need supplemental cooling. I'm just not sure of the circumstances that you would want to do that. If you want to shoot several short takes in 100 degrees, you'll have the fans set to a higher speed when in standby. If you are not shooting sound, you can turn the fans up and shoot very long takes in high heat. If you are shooting high frame rates, heat management is more important than 24fps. If you shoot 3K instead of 5K... heat management is less critical.
    So... yes, there is a limit just as with every camera. But you can use these cameras in just about any situation and make them work.
    Conversely, if you are shooting in the cold you will likely turn the fans down or off (very cold). There is an AUTO setting that will help you through this. The range of these cameras is very wide. The fans are designed to keep you in the range. Remember that you have the capability to shoot 5K at 120fps. That is a miracle in and of itself. The fan management is part of what lets you shoot this kind of data at 100F.
    In room temperature... you can set the fans to be very quiet in standby and silent for recording. Silent recording is an option at all temps. The hotter it gets the higher the fans should be in standby.
    Everyone was afraid of the RED ONE over-heating. We haven't heard a single complaint for years. This is partly due to heat management system we put in and partly due to the fact that customers have recognized when they need to step in and put a white umbrella over the camera when it sits in the desert all day.
    Jim
    "The camera is arguably one of the most important of all inventions… it is the single tool that has the ability to stop time, record history, generate art, tell stories, and communicate messages that transcend language like nothing else ever conceived."
    "Everything in life changes... including our camera specs and delivery dates..."
    We reserve the right to refuse service to anyone with a bad attitude.
    Senior Member Joseph Hutson's Avatar
    Jan 2008
    Dubai/USA/Anywhere at a Moment's Notice
    :Sigh: I guess I'm the one to blame on this. I actually adjusted audio to accentuate the fan noise, in wanting to let people know that the fans DO go entirely quiet during recording. I unfortunately did not factor in the idea that someone might come away with the opposite feeling of a fan being "too loud" while not recording.
    The fan is not at all unreasonably "loud". And that's without factoring in how much horsepower that is being used within such a small container...
    CINEPHOTOGRAPHER | Dubai
    TWITTER | @Hutson
    The answer is "No" 100% of the time you don't ask.
    Member Michael Shilnov's Avatar
    Sep 2010
    Sweden/Ukraine/Illinois
    Thanks for that insight Jim...
    Since I wanted to check out the native sensor, I didn't shoot any HDRx™ in Utah. In the darker areas of the sequences I shot, we definitely experienced low noise - even in the dark tunnel driving sequence. Those boards are very efficient..
    Wow, I thought the canyon shots with lots of shadow/sunlit areas had were at least mildly HDRx™-ed. What time of the day did you shoot them?
