Thread: DAVINCI RESOLVE and ***HACKINTOSH***
Page 56 of 60 FirstFirst ... 646525354555657585960 LastLast
Results 551 to 560 of 595
  1. #551
    Apr 2008
    Bangalore,India
    Hi Lugi..... your help required...
    I have done fresh install of 10.7.0 -
    2 x Nvidia GTX 270 are in slot no: 5 and 7 ( no 9800 GT )
    i have installed machete - option 2 Quadro 4000
    Problem is after Installation :
    Graphics option : 1200x1600 only
    No Cuda Support
    Do i need to update anything else ... Please help.
    Regards
    Arun Kumar
    REDOne 21XX
    " The best journeys are not always in straight lines "
    Senior Member luigivaltulini's Avatar
    Oct 2009
    Switzerland- LUGANO
    Arun,
    you have a extra folder in root directory?
    if you have , send to me at luigi.valtulini@gmail.com
    thanks
    luigi
    TELEVISION BROADCAST SWITZERLAND
    www.rsi.ch
    Color Correction DAVINCI Resolve/Digital Workflow/Red Camera Rental
    EPIC #599 and #668
    SITE
    www.cine5k.ch
  3. #553 HP Z820
    Junior Member
    Mar 2012
    The new Z820 is now released for sale per HP. Looks like it's time to work on a new Hackintosh!!
    Senior Member Barry Bishop's Avatar
    Oct 2010
    USA-California
    Quote Originally Posted by John Cox View Post
    It doesn't have two Xeons in it?
    NVM its an added accessory.
    Oct 2009
    Switzerland- LUGANO
    hehe of course, for now I do not change my hp z800, the output aspect of the new mac pro, we hope to have 6 pci-e. Sincermante thunderbolt I do not do anything. Unfortunately it is still a bottleneck.
    If mac pro will not come out. maybe I'll change 'with the HP z820, for now I do not have money to burn in this PC I prefer to keep updating the sensor Dragon.
    But if any of you have already ordered this wonderful PC, you could try.
    You should pay attention to the chipset is new and now in the kernel is not supported, there may also be problems with speedstep as the network card .... I wait a bit. Surely as Linux or Windows machine is fantastic, if only doing the Resolve ProRes for Windows ...
    I wait to see if someone Forum reduser the test, maybe Jeff Kilgroe will give us some more information.
    thanks
    Luigi
    www.rsi.ch
    EPIC #599 and #668
    SITE
    www.cine5k.ch
    Member Arun Kumar's Avatar
    May 2008
    Bangalore,India
    Hi Lugi,
    I have updated my system ; below is detailed config :
    ( slots from Top to Bottom )
    1. ESATA
    2. BMD Decklink HD
    3. GTX 470 --------- ( GUI Monitor )
    4. Empty
    5. GTX 470
    6. Empty
    7. GTX 470 ,
    12 GB RAM , 5 x 2TB = 10TB Internal ( Apple RAID 0)
    Playback frame rate is too slow in Resolve ;
    Decode Quality : FPS Playback
    a. One-Eighth Res Good : 3 FPS
    b. Quarter Res Good : 2 Fps
    I have checked Disk Speed test using BMD Disk Speed Test - Test shows 590 Mbps +
    Please help me to resolve this issue:
    Arun Kumar :-(
    Arun Kumar
    RedOne 22XX
    RedOne Rental - EDIT - VFX - DI - POST - Supervisior
    Aadithya Visuals
    Bangalore,India
    www.aadithyavisuals.com
    Junior Member
    Jul 2011
    Budapest, Hungary
    Hi, I have a problem within the Asus P6T7 Supercomputer system.
    The 2 Esata-external port doesn't work either on P6T7 Supercomputer,
    (does not work at all with "new" AppleVIAATA.kext).
    I need some help, I looking for the solution......
    Oct 2009
    Switzerland- LUGANO
    Quote Originally Posted by peter semmi View Post
    Ciao Peter,
    external sata don't work in p6t7.. my patch is only for testing.
    thanks
    luigi
    www.rsi.ch
    EPIC #599 and #668
    SITE
    www.cine5k.ch
    Oct 2009
    Switzerland- LUGANO
    Quote Originally Posted by Arun Kumar View Post
    Hi Lugi,
    1. ESATA
    2. BMD Decklink HD
    4. Empty
    5. GTX 470
    6. Empty
    7. GTX 470 ,
    Arun Kumar :-(
    Ciao Arun.
    driver cuda is ok? version?
    post here your debug preferences, and try old davicni resolve 7 , only for test copatibility, just for try.
    thanks
    Luigi
    www.rsi.ch
    EPIC #599 and #668
    SITE
    www.cine5k.ch
    May 2008
    Bangalore,India
    Hi Lugi,
    CUDA Driver Version : 4.1.28
    GPU Driver Version : 7.4.10 270.05.05f01
    Debug Pref:
    LsManager.3.NumGPUs = 3
    LsManager.3.GPUMapping = 0 1 2
    LsManager.3.GPUMappingEnable = 1
    Regards
    Arun
    Arun Kumar
    RedOne 22XX
    Aadithya Visuals
    Bangalore,India
