I tried to set up my system with Luigi's guide (thanks again for it!). I installed OSX from a MacMini to an Sata hard disk drive which I connected later to the Sata1 port on the P6T7.
Unfortunately, after the BIOS screen, all I see is a blinking underline.
My setup (from CPU downwards)
1 - empty
2 - empty
3 - GTX480
4 - Decklink 3D+
5 - GTX480
6 - Areca RAID 1880-i (8 port sata)
7 - GTX480
I can't really change this setup, since all 3 GPUs are connected over a watercooling bridge which I don't really want to take out since it took me already years to make it work.
And the other cards are under that bridge (Aquacomputer Twinconnect). Does someone know where the error might be? Or how to integrate drivers into the OSX installer?
There's an other walkthrough (http://aquamac.proboards.com/index.c...ay&thread=1062) but it's configured for 2x GTX285.
I got the files for 3x GTX480 (http://aquamac.proboards.com/index.c...lay&thread=509) and installed them into the com.apple.boot.plist on the OSX install (the hard drive, not the 1GB USB bootloader).
But without success.
Does someone know if I can first install to a normal drive and then (if it finally works) somehow clone the install to the RAID?
