There is a shorter interconnect cable than the one shown in the video; in practice there is nothing to snag there (see attached image)The monitor appears to be attached by a cable. I've seen this with all of RED cams. So it goes from the monitor to the Red Brain I assume?
Why doesn't RED make it so you can slide or snap the monitor in to the body without having any loose cables around. I know this seems minor, but I'm just really curious. It would look so much "cleaner" and less things in the way when you are doing the run and gun...less to obstructions.
Correct. Up to 10 ft away from the Brain as a minimum, maximum range to be confirmed.I think it is so you can mount the monitor wherever you want and not be locked into having it only in one place.
Also it allows us to offer several different types of monitoring option, such as Touchscreen LCD, EVF etc
