Click here to go to the first RED TEAM post in this thread.   Thread: REDCINE-X Build 351... finally.
Page 13 of 23 FirstFirst ... 391011121314151617 ... LastLast
Results 121 to 130 of 225
  1. #121 eyeon Fusion
    Senior Member Stivan Widick's Avatar
    The Most-Chosen City on Earth
    Bravo! I want eyeon to implement this in Fusion ASAP. Fusion 6.1 has had full support for Color Science 1 & 2 for a long while so I hope their devs keep in close contact with RED. Think I'll give them a call...
    Epic-X #01895 (23) "Jughead"
    Senior Member Rami Mustakim's Avatar
    Jan 2008
    Paris, FRANCE
    Functional QT wrappers would be perfect ;-)
    Senior Member Chris Luker's Avatar
    Mar 2007
    Salt Lake City, sometimes France
    I shot a small clip on a standard RED M at 4480X1920 23.98 and every time I try to export a 1080p quicktime, I get "Finished with errors" "Error applying crop or scale: frame:5".
    I've tried cropping to a better mathematical size, same thing. Tried bunches of different quicktime settings to no avail.
    This on PC XP 32bit and Mac 32bit versions.
    The file plays fine in the Player, I just can't export a quicktime from it.
  4.   Click here to go to the next RED TEAM post in this thread.
  #124
    Red Team
    Sep 2009
    Irvine, CA
    Quote Originally Posted by Quentin_B View Post
    I'm getting the same problem with REDLINE set to 4. All QT's come out short of the file size expected and won't open anywhere except for some reason the last 2 which are fine.
    I had this problem with build 348 too but it usually applied to only the first 4 (or however many Redlines were set) clips in a batch export. Whatever has been done to make multiple redlines continue processing multiple files throughout a batch has made more of them go screwy.
    Hi Quentin,
    Did you see my earlier post (#78):
    http://reduser.net/forum/showthread.php?t=51413&page=8
    If you can confirm, that would be great.
    Again, having simultaneous REDLine's running trying to export to the same file is a no go at the moment.
    David
    Senior Member Miltos Pilalitos's Avatar
    Jan 2007
    Athens, Greece
    Quote Originally Posted by Stivan Widick View Post
    I left a message in the Fusion forums yesterday so i guess Daniel or Eric must have seen it.
    Miltos
    www.pilalitos.com
    EPIC-X #418, RED-MX #1473, RED ZOOM 18-50, RED ZOOM 50-150, Duclos Tokina 11-16
    I appreciate all the fixes to this build... however where is CamRGB color space?!?
    The new color and gamma spaces are great, but I need to be able to recreate exactly how I have previously transcoded footage so my grades apply exactly as before. Backwards compatibility is essential. Please when you add options don't take away key old options.
    Brandon Kraemer
    Editor / Colorist
  7.   Click here to go to the next RED TEAM post in this thread.
  #127
    Red Leader Jannard's Avatar
    Quote Originally Posted by Brandon Kraemer View Post
    Go to prefs and select "Show Advanced Controls". They are all there.
    Jim
    "The camera is arguably one of the most important of all inventions… it is the single tool that has the ability to stop time, record history, generate art, tell stories, and communicate messages that transcend language like nothing else ever conceived."
    "Everything in life changes... including our camera specs and delivery dates..."
    We reserve the right to refuse service to anyone with a bad attitude.
  #128
    Quote Originally Posted by Leif Thomas View Post
    I encountered a huge problem with the new driver / firmware for the RedRocket!
    Hi Leif, can you please shoot me an email? rob at red dot com
    ROBCODE Santa Claus @ RED
    "You get the chicken by waiting for the egg to hatch, not by smashing it with a hammer" - Jarred
  9.   Click here to go to the next RED TEAM post in this thread.
  #129
    The shortcut "Shift Z" - fit timeline to window - doesn't work anymore (at least in the OSX 64 version). The corresponding menu-item still works though.
    Thanks for reporting this. The shortcut will be enabled in the next build, and be customizable.
    Quote Originally Posted by Jannard View Post
    Jim
    Yes, they are. Thanks.
    A bug that still lingers...
    Exporting Timeline (all clips) still prompts for a file name, despite the fact that the preset is set up to use source name. I still have to switch into Timeline (selected clips) and then select all clips in the timeline to do a batch export.
    Brandon Kraemer
    Editor / Colorist
