How well do HDR modes deal with transients (Strobes, fireworks etc)?
JohnF
JohnF
I think Sanjin you underestimate just how awful DSLRs are as tools on sets that are not "personal project oriented", and where, if, say, a shot is ruined due to moire or some other problem, it means an expensive re-shoot and likely a lost, valued client. I'd much rather a solid 2/3rds cam than a shaky full frame that lets me down half the time.
Isn't it likely that HDRx is essentially exposing two "fields" (sort of like interlace except they are each full resolution) so call it "48fps-24P/24P+/-3" and using two different shutter speeds to get two different exposures?
Then those two frames are combined, possibly with some interpolation?
And this gives you the FPS limitation since 48fps HDRx is really "96fps-48P/48P+/-3" and some of the remaining processing power has to go to overhead?
I don't think that's how they're doing it. It's been said that there is no temporal offset or sequential frame capture. My guess is they have a way to take two distinct exposure readings from the same read/reset cycle on the sensor. Thus creating two differently exposed frames, but from the same instance in time, therefore no motion issues or interpolation to deal with. However, having two different exposures from the same sensor read-out still creates two images and uses 2X the rate.
Once the cameras are out, we will get a better idea. If the HDRx mode does not work with a 360 degree shutter, then two fields sounds plausible. But, although not familiar with the hardware limitations, would rather guess that they manage to read every line of the sensor twice or something like this. Besides, Jim showed this image with waves on the sea. It's difficult to conceive interpolatation between such fields you suggest would work out in this case.
Jim, I was at IBC and TED showed me the EPIC and I agree totally with you: There is NO other camera, that will give me all these advantages, from every point. ALEXA is a great product and will find there costumers, no doubt. But my heart beats for revolution AND resolution AND dynamic range AND design AND less money for more camera AND weight AND... You are incredible guys, thanks.
Hi Rob, Not really wanting to enter into another mind numbing theoretical/hypothetical heated debate of Epic vs. Scarlet vs. 5Dm2. But from your comments it sounds like you are having a harder time using current HDDSLR than may be necessary. It is possible to shoot with cams like 5Dm2, and never disappoint your clients, in fact quite the opposite. I've never let any clients down shooting HDSLR and I've used that "brain" in a variety of types of shooting (mostly commercial and narrative). Red has done a masterful job of positioning Epic/Scarlet brains as the sensor technology around which an acquisition technology and workflows need to be applied. Same thing for cams like 5Dm2.
Anyway. This is not a HDSLR forum, but if you would like to know more about my approach to working with the 5Dm2, which generally guarantees client satisfaction, contact me offlist and perhaps it can be of help.
So I think you're suggesting maybe they read the same row of pixels twice before moving to next line?
Do we know if the exposure offset has to go in one direction I.e +3 or minus three from what is set? Or are there 3 exposures? One plus and one minus? Or am I missing something obvious? :)
