Thread: Cyclone 600-2707
Page 1 of 8 12345 ... LastLast
Results 1 to 10 of 78
  1. #1 Cyclone 600-2707
    Anyone use the Cyclone 600-2707 PCIe expander?
    http://www.cyclone.com/products/expa...s/600-2707.php
    x16 gen 2 Host connection
    3x x16 gen 2 slots
    2x x8 gen 2 slots
    I am planning to get one unless I hear someone has had a bad experience. The engineers told me they have customers using them with Red Rocket. Are any of those users here?
    Thanks,
    Dusty
    Banned
    Mar 2007
    Athens Greece
    I am also interested to buy one 600-2707 PCIe expander. Any comment will be useful.
    Senior Member Kaku Ito's Avatar
    Feb 2008
    Chiyoda-ku, tokyo
    This one clearly shows the possibility for two GPUs and two Rockets without compromising. But peeps say Mac Pro only provides total of x40 lane. GPUs taking total of x36 and RRs taking x16 which totals 52. Host (Mac pro) would probably switch which ever slot down to x4 maybe?
    Kaku Ito
    rawesome! Equipments
    RED Epic-M, RED Epic-x, RED ONE MX x2, RED ONE Mysterium, Allstar A-mount, Epic Canon Ti Mount, 1.8' SSD modules, RED PRO Prime Set (18 through 100mm), various Nikon and Zeiss Lenses, 17-55mm RED Pro Zoom, 18-85mm RED Pro Zoom, x2 RED ROCKET, Mobile Rocket, DaVinci Resolve, Cubix, GTX-285, Quadro 4000, few Mac Pros, few MacBook Pros, Sony BVM-D24, Panasonic 65 inch Series 12 plasma, Calman with Klein probe.
    Rawesome! One Stop RAW Visual Production Service
    I just ordered my 600-2707 today. There is a backorder, but I will let you know how it works once I get it.
    Basically the Mac Pro has a total of 40 PCIe v2 lanes. 16 of those v2 lanes are used by the 600-2707 host adapter.
    The 600-2707 has 64 PCIe v2 lanes that go through a switch and connects to the Mac Pro via 16 v2 lanes. So anything you put in the 600-2707 will be limited by what the switch can get though the host adapter. Until I test, I don't know how that is going to effect performance.
    I do know the Rocket is only x8 v1 PCIe, which is the same throughtput as x4 v2 PCIe, so there is lots of leftover room for other cards.
    Dusty
    Senior Member Shane Betts's Avatar
    May 2007
    Melbourne Oz
    Very interested in your findings Dusty. Yes, the Mac has a limited number of lanes but the number of actual slots is worse. Thanks for taking the plunge.
    Cheers
    Bettsy
    Feb 2008
    Chiyoda-ku, tokyo
    Quote Originally Posted by Dustin Cross View Post
    Dusty
    Kudos to Dustin.
    Kaku Ito
    Feb 2008
    Chiyoda-ku, tokyo
    From my Magma experiences, many cards work fine in PCIe expansion.
    So far, RED ROCKET, SmallTree 10Gb ethernet card, ATTO R380 (which works for Mac Pros and Xserve but not when connected to Mac Book Pro), eSATA card, Matrox MXO2 host card and so on. Only thing didn't work was LSI and ATTO fiber channel card.
    Kaku Ito
    I am planning to have these cards in my system:
    GTX 285
    PCIe Expander card
    Red Rocket
    Atto R60F
    Sonnet PCIe for QIO
    Matrox PCIe for MXO2 LE
    I was planning to put my Sonnet eSATA card in, but the QIO takes care of that right now. Might still put it in.
    Might add a Kona 3G if it doesn't interfere with the MXO2
    If I get Resolve I'll need a second video card
    With the 600-2707 I should be able to get all of this in one system and organize things so I have proper performance.
    Dusty
    Senior Member Tom.Wong's Avatar
    Jul 2009
    New York/New Jersey
    Kaku if you don't mind me asking, can you write out your full set up at the moment? Which magma expander, what cards you have on your mobo, what slot you have connected with magma, and what cards are in magma right now? I want to expand out too, hopefully prep for a resolve soon, and would like to gauge to see results of what works, here and now.
    Feb 2008
    Chiyoda-ku, tokyo
    Dustin,
    Kona does not take any other similar card at all. You won't be able to run both MXO2 and Kona.
    Tom,
    I have the ExpressBox2 which expands one slot (so the box has two slots, take away one slot in the host computer). I chose this model because it runs at x8 when you connect it to Mac Pro and also works at x1 when you connected to Mac Book Pro.
    I had the RR and an eSTATA card in the magma, they worked fine both with Mac Pro and Mac Book Pro. When I connect it to Mac Pro, I have the host card plugged in the second x16 slot and RR is recognized at x8 speed no problem. I was hoping something like R380 works for the Mac Book Pro combo, but unfortunately did not (it could be the firmware issue with R380, I should give a try again since it is working with Xserve right now).
    Now I have a iStoragePro Express 1 with 1 slot expansion which holds RR better with same footprint of Mac Book Pro 17inch, so for portable DIT system, I take this for RR mobile use. So my magma went to Xserve to provide extra PCIe for connecting extra R380 and it is working fine.
    For MacBookPro, something like Express 3 could be the best (http://www.istoragepro.com/prod.php?id=id8exp3). But for Resolve, I'd choose Cyclone if we hear good things from Dustin.
    Kaku Ito
