Originally Posted by
Marco Materassi
Hello
I really need an advice about exporting. I need to export a construct keeping the shots. If export from the node from the construct, I can export only the main construct into a single file (or image sequence). My goal is to obtain all the clip rendered as single files. From the player I can export each single shot but since I have to apply a fx ctrl to each one (need to add a quicktime exporter), it takes forever. Is there an easier solution?
Thank you so much
