Thread: Red MultiCam live Mixing for Cinemas
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1 Red MultiCam live Mixing for Cinemas
    Senior Member jimhare's Avatar
    Sep 2007
    Sydney Australia
    Hi,
    I do a lot of Red multicam shooting in live theaters in Sydney Australia, and have gotten this to a science the last couple of years.
    I am now being asked to do a live cut from the Reds, and microwave the signal about 4 blocks so it can be streamed live into cinemas around the country. Live mixing and transfer of 5.1 audio as well...
    On the surface, no problem! Whack an HD-SDI mixer in there, hire a company to microwave the signal and done.
    But it gets more complicated quickly. Initially we'll be limited to 720P until Epic comes out, there is no CCU so we will be calling for manual iris pulls etc. The audio signal will need to be delayed to match vision, I'm thinking by up to 6 frames by the time it is mixed...
    The O/B companies will want nothing to do with me so I'll need to dry hire or bring in a producer to coordinate everything...
    Does anyone out there have any advice or past experience for me?
    Thanks!
    Jim Hare
    Sydney Australia
    Quote Originally Posted by jimhare View Post
    understandable, a triaxx or multicorecable is all what they are used to...
    I would recommend GrassValleys mobile Indigo with the extensionboard (8 HDSDI in) because the most important things are built in:
    build in colorcorrection for each input, when you canīt align the cameras exactly as you need for live, depends of how much control do you have for the enviroments (light, position etc)
    build in audio delay management for HDSDI out with embedded Audio. (you can make your own mix in the build in audio mixer - 4-band parametric equalizer and motor-driven audio faders).
    To my experience the delay is around 80-100ms. If you presync the cameras it should be shorter but needs extra cabelling and a trilevel syncgenerator. (I never used it)
    720p is ok because most of the mobile mixers undestand only 1080i.(the mixer could convert to 1080i if needed for the microwave)
    You can run approxm 100m with good cables, you will need an additional audiocable for Intercom (director to each camera) or wireless (expensive)
    Rehearsals and strong nerves for the director and the cameramen
    btw. build 30 with clean feed and CLR view works far better as earlier builds
    good luck
    bg
    alex
    Alexander E. Horvath
    tv multimedia & specialproduction
    Austria
    A NewTek Tricaster might be able to do the job for you. An added advantage would be you could stream it yourself and eliminate the microwave stage.
    http://www.newtek.com/tricaster/
    The TCXD300 has 3 SDI inputs. The TCXD850 has 8. Each input has a proc amp.
    Good luck.
    "All right, they're on our left, they're on our right, they're in front of
    us, they're behind us...they can't get away this time"
    - Lewis B. "Chesty" Puller, USMC
    #6893
    #6894
    #6895
    #6896
    Sep 2007
    Sydney Australia
    Hey Guys, thanks for the advice!
    Jim
    Senior Member Tom Gleeson's Avatar
    Nov 2007
    Sydney
    I am sure the Grassvalley is a good solution but alternatively you could line up all your cameras shooting a single chart and go into the Video Menu and you have sufficient adjustment to line up the cameras. Its not the most efficient process of bringing your cameras into line but would work.
    Unsure how tolerant modern vision mixers are but I suspect you would be best served running all the cameras off a single SPG producing trisync. You will need to run a cable to each camera anyway so running a second cable for sync is not much harder. High quality cables would be a must and hopefully cable runs are not too long.
    The microwave link van may be able to sort out the audio delay? I have some good contacts for setting this up if you are interested.
    Tom Gleeson
    Senior Member Jeremy Wiles's Avatar
    Nov 2008
    West Palm Beach, FL
    Quote Originally Posted by Roger Crouse View Post
    Roger, I have the NewTek Tricaster and I can't get a feed on the RED camera. However, I don't have the latest Tricaster. I was told by Tricaster it can't pull signals from certain cameras.
    Dec 2008
    Quote Originally Posted by Jeremy Wiles View Post
    Jim, do you still need this info...?
    Jeremy, you have to use the Tricaster 3 or 8 series - they are the only ones that pull the HD-SDI signal into the box...All other series are SD only.
    Our team ran two Red Ones for Ketch's Epic Houston Tour...signal was amazing and Tricaster handles it well.
    The streaming services are still not up to par for us - both have issues we would like to see corrected if they want to leave the UGV world
    Nov 2008
    West Palm Beach, FL
    Thanks, Jack. That's good to know.
    Junior Member
    May 2011
    Philadelphia
    Heh Jim, I'll give you a call. One of my colleagues up here as a new great setup for this type of thing and is a built flyaway system. it's a tricaster i think but can't be too certain. All i know is they have already done a few multicam jobs including a RED with it. I know a bunch of OB techs as well that are freelance and should be able to help. Anyway, will call you...
    Brigham Edgar
    Cinematographer
    www.brighamedgar.com
    Brisbane, Australia
