Thread: 3D rig from film factory...
Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
  1. #1 3D rig from film factory...
    Senior Member Cristina S's Avatar
    Mar 2008
    Any reviewers on this rig?
    http://www.3dfilmfactory.com/index.p...d=44&Itemid=76
    I've just found this:
    http://parallaxfilm.wordpress.com/20...ter-indie-rig/
    But I'd like to listen other people. Thanks.
    Senior Member Zac C's Avatar
    Salt Lake City, UT/Cape Cod, MA
    Ugh, I used this on a 3d film with Sony EX3's and what a horrible experience, the entire built quality just feels like a chinese knock-off, things could be moved around to easily, and the glass just didn't hold up when you needed minute adjustments.
    I could go on for hours on how much I didn't like the rig
    Scarlet-X "Starbuck"
    I have it, now i'm installing it with 2x redone. In days i can make a better report.
    First report, you get what you pay.
    I'm figuring how to align vertical of the cameras. Its my mayor problem now. I will atach a motor for IO, i think it's simple. But convergence will be a real problem. I must make something "in house" because i need something more fluid (and if possible motorized)
    My initial opinion is: it's too big. I think it can be smaller. The glass can be much better (the price is to low). The adjustement of the IO is ok!, I like this system, is heavy but work well.
    When I setup all componentes and all work perfect, I'll back here to post a small review and final opinion about 3d film factory.
    For now... do you know where i can find a better glass?
    In other part,
    I have problems with zooms. The center change between 2 cameras... so, no zoom possible without new adjustment. I don't know if the problems is the zooms... or the cameras... but this is important to have in mind.
    saludos,
    Jose.
    Jan 2009
    Quote Originally Posted by Jose Lome?a View Post
    How and how much?
    Again, how and how much will you spend?
    ________
    Pop Stocks
    Mar 2008
    Quote Originally Posted by Jose Lomeña View Post
    Are you meaning the mirror?
    Mar 2008
    In other part,
    Even if you use the zoom as you'd be working with primes?
    Jun 2010
    You could call Element Technica and talk to them about replacement mirrors or check out either these sites.
    http://www.stereoscopicmirrors.com/
    http://www.zgc.com/webstore.nsf/products/pstech_24019
  8. #8 specs
    Senior Member Jacek Zakowicz's Avatar
    Jun 2008
    Quote Originally Posted by Brian Petrie View Post
    I'd call Element Technica and buy a replacement mirror from them. They range from like 500-5,000 dollars depending on quality. Or check out these online:
    Don't know about the quality from these guys but you could check them out.
    Or check out this site which sells a replacement for the p+s technik rig. Which if oem should be of high quality.
    I love it when someone randomly makes a statement about a part without the knowledge.
    What exactly does"better" mean here?
    flatter(and how flat)? coated(what coatings), any other considerations?
    or just spend $500-5000 and hope it works?
    lovely.......
    Jacek Zakowicz, Optitek-dot-org, jacek2@optitek.org
    Professional Broadcast and Digital Cinema Equipment
    Quote Originally Posted by Cristina S View Post
    Yes
    If you are working like primes no problem you can adjust the mirror. But if you want to be faster without any adjustement between diferents focal you need a 2 factory match zoom for 3d... At least my lens don't match.
