Thread: Workstation Configurations - Listings
Results 1 to 8 of 8
  1. #1 Workstation Configurations - Listings
    Please list your hardware configurations here for workstations used in your RED workflows. Format should be as follows. Please, no discussion or questions about these configurations in this list. Take all discussions to the discussion thread: http://reduser.net/forum/showthread.php?t=46968
    Hardware Configuration:
    Primary OS and Software used:
    Pros:
    Cons:
    Misc Notes:
    - Jeff Kilgroe
    Apr 2008
    2.66 ghz 8 core 2008 Mac Pro 8GB's ram, rocket card
    Primary OS: OSX Snow Leopard
    Pros: works great, runs great, likes RED
    Cons: Lugging that behemoth of a box around. It really gets to be a pain when your hauling it around for DIT work. Not the easiest thing to get in a cart either.
    Misc Notes: I think shortly I will be giving an Xserve a try. So much better for hauling around and takes the abuse off my Mac Pro
    Ian Laurie
    Senior Member nima's Avatar
    Apr 2008
    New York City
    We use this configuration for 2k and 4k editing and grading:
    Hardware configuration: Boxx i5, 24gb ram - Dulce raid drives
    Primary OS: Windows, Premiere CS4, Assimilate Scratch Cine
    Pros: very efficient delivery of multi formats,plenty of monitoring options and raid configurations.
    Cons: not so cheap, right?
    RedOne MX and Epic X - Boxx Systems
    Assimilate Scratch Finish - Dulce Raid
    Apple Hardware
    Sep 2007
    West Los Angeles
    2.93 Ghz 8 Core Mac Pro, 16GB Ram
    G-Speed 6 TB usable Raid Config
    Red Rocket
    Decklink HD-SDI
    30" Apple Cinema Display
    17" Panasonic BTLH-1700W Monitor
    50" Viera Plasma Display
    Euphonic MC Color Control Surface
    Mac OS 10.6.4
    Final Cut Suite
    Adobe CS5, Premiere Pro, After Effects
    Color runs with the decklink card
    Redcine runs with RR
    both output displays mirror on the 17" panny and 50" plasma at the same time.
    Pros: Fast when everything is working, the 50" plasma looks awesome in the dark studio and impresses clients
    Cons: Lack of tight integration between Color and native .R3d files. RedCine crashes, bugs with redrocket on occasion
    - Travis MacRitchie - Epic, Scarlet, Sony F55, F3, C-300 - Optimo DP Rouge 16-42, 30-80mm, Fujinon Cabrio 19-90mm, Arri Ultra Primes, Zeiss Compact Primes, Red Pro Primes and Zooms
    BrainBoxCameras.com
    310-773-4823
    HD and RED Camera Rentals / Director of Photography
  5. #5 Mac Pro (2008) ok for DaVinci?
    Senior Member Curran Giddens's Avatar
    Jan 2007
    Berkshire County, Massachusetts
    Mac Pro (2008) 2 x 3.2GHz Quad-Core Intel Xeon
    16GB RAM
    nVidia GeForce GT 120
    Blackmagic Decklink HD Extreme 3D
    4 x Hitachi 2TB Enterprise Series
    1 x 120GB Mercury Extreme Pro SSD 2.5" SATA boot drive
    1 x SATA media transport drive
    MaxConnect internal HD mounting solution
    RED Rocket
    RED Rocket Breakout Box
    HP Dreamcolor 24" 10-bit LCD
    Apple 30" Cinema Display
    Wacom Intuos4 Large
    Tangent Devices Wave
    *For DaVinci I just need to add a nVidia Quadro FX4000 when released in Oct.
    SOFTWARE
    Mac OS 10.6.4
    DaVinci Resolve 7
    Adobe CS5
    ABSoft Neat Video for AE
    R3D Data Manager
    Clipfinder 2.5
    Apple Logic 9
    It is a bit of a hassle to get the SATA cables plugged into the motherboard. I had to loosen the screw (circled) holding the fan in place and pull up on the entire fan assembly in order to get the cables plugged in. Getting the cables through to the optical drive bay was also a tight fit. But it was all well worth the effort.
    AJA disk test on my 4 x 2TB internal software RAID 0.
    http://www.SolarSystemStudio.com/
    EPIC-M #508, EPIC-X #124
    Senior Member jake blackstone's Avatar
    Nov 2007
    Quote Originally Posted by Curran Giddens View Post
    8GB RAM
    ATI Radeon HD 2600
    2 x Seagate Barracuda 750GB Enterprise Series
    RED Rocket
    Wacom Intuos 9x12
    Mac OS 10.6.4
    For DaVinci will I need to add 4GB more RAM, nVidia Quadro 4000, nVidia GT120, Blackmagic Decklink HD 3D, and Tangent Wave.
    Thanks for great pictures and info. I think I'm going to do the same thing, if I to decide to use the Red Rocket and forgo FC controller.
    My understanding, that Resolve "likes" either 6 or 12 GB of RAM, but I'm not 100% sure on that.
    Unfortunately, although, Resolve on 2008 Mac will work, it will no be capable of real time playback without Red Rocket. Only 2009 and up...
    But seeing, that you've got Red Rocket, you good to go.
    Apr 2009
    Singapore
    Its actually the Nehalem architecture in the 2009 MacPro that prefers the system ram in lots of 3. For those trying 2008 MacPro, 8GB is likely to be better.
    Peter
    Apr 2008
    New York City
    Quote Originally Posted by nima View Post
    forgot to mention a red rocket to speed up the process
    Apple Hardware
