Project has been cut on FCP using _H proxies. Some scaling required and incorrect colour temperature on metadata. Short form.
One possible workflow that I am trying out is to use TP2 to generate a .lua file for RedCineX and 'Relink' to generate an xml for FCP afterwards for roundtripping. Coming across a couple of issues.
1. RCX export options 'Timeline (selected clips)' with all clips selected generates .mov files for each .r3d correctly named. Unfortunately the timecode in those .mov files is the 'AC' code not the 'EC' code the FCP timeline is linked to. Is there a setting to tell RCX which code to put in the file?
2. RCX export option 'Timeline (all clips)' generates a renamed, flattened .mov of the timeline. Is there a setting that will tell RCX to export seperate .movs per .r3d?
Many thanks
