Click here to go to the first RED TEAM post in this thread.   Thread: Redcine-x Transcodes to Prores 4444 look WASHED OUT
Page 3 of 14 FirstFirst 123456713 ... LastLast
Results 21 to 30 of 136
  1. #21
    Senior Member Johnny Friday's Avatar
    Feb 2007
    La Paz, Baja Ca. Sur, Mexico
    Quote Originally Posted by David Battistella View Post
    Looked at all the files in FCP and here are the results.
    Correct gamma compared to RC-X
    PR4444
    PR422 HQ
    PR LT
    DPX
    Raised GAMMA (blacks) compared to RC-X
    DVPROHD
    UNCOMPRESSED 10 bit
    SHEER
    PR Proxy
    PR 422
    What a Charlie Foxtrot this is.
    If I open all of these files in QT the reverse happens with ProRes.
    Advice.
    Before creating a deliverable. Know what software the files will be edited in. Test. test . test.
    David
    Yes, that is about what i experienced. ALTHOUGH for my looking at underwater footage with big blue background with raised whites....I can see in MUCH greater detail the washout effect. If i import that pr4444 into FCP it does look better, but still not nearly as good as in RC-X--i would not say that it matches the look, but just has 50% better saturation as compared to viewing it in QT
    John Friday
    La Paz, B.C.S., Mexico
    www.bajaproductions.com
    EPIC M & 2X for 3d & Deep Epic Underwater Housing
    RED MX with SSD & Underwater Housing
    Feb 2007
    Here is a TIFF file that I had worked from Rocketcine-X using dreamcolor monitored from HD-SDI thru AJA to HDMI so viewing and correcting at 10bit with dreamcolor monitor set to "FULL" as colorspace with the Gamma in FULL mode set to 2.2
    Looked great on the Dreamcolor monitor, but on my Mac via DVI and ATI 4870HD graphics card at 8bit using Mac's gamma of 2.2 it looks washed out and de-saturated. Not sure if this screenshot will do this rant justice.
    Comments?
    EDIT: the screenshot does not show anything....since i have no reference.
    John Friday
    Feb 2007
    Ok....I think I've run out of ideas and tests. I would be perfectly willing to send you guys a clip to see for yourselves what i have tested. Say (as David suggested) a small 2-3 second clip to see for yourselves. It would be however nice if one of you had a dreamcolor to monitor extactly what i see, but at the least a QT prores 4444 clip transcoded may tell???
    John Friday
    Is this not because the dreamcolour is a wide gamut display ?
    going to 8 will clips/distort your chroma in an image no ?
    s
    MatteBlackFilms
    Space Digital Visual Effects & Post Production
    Feb 2007
    Quote Originally Posted by Simon Blackledge View Post
    s
    I don't think so...In fact have some new examples to show the HUGE change in flavours.
    John Friday
    Feb 2007
    Here are two screenshots of the EXACT same image BUT one was corrected in Redcine v 20 and the other in Redcine build 221 with redcode QT component 4.1 added.
    You'll notice a big difference in the saturation in the two shots. I had originally corrected the RCv20 image using my Dell U2410 and the image showed on my non-calibrated screen nicely, but on a REC.709 it is darker and more saturated--but the difference is not ovewhelming.
    The image RC-X-build221 was corrected using RC-X and corrected on my Dreamcolor emulating REC709. Looked great while correcting on the monitor, but when I output a QT it looked terrible and washed out.
    CONCLUSION: i can only come to the conclusion (no science--only my eyes and two days of testing) that RC-X build 221 and the new QT component are not outputting the new color-science correctly. It is clear that with Redcine V20 i could get images to look fairly close to what i saw them looking like in Redcine and the prores transcodes, but that is NOT the case in my recent transcodes using build 221.
    Comments?? other ideas?
    John Friday
    Feb 2007
    I can't be the only one experiencing this problem??
    This a huge difference.....
    John Friday
    Senior Member Kaku Ito's Avatar
    Feb 2008
    Chiyoda-ku, tokyo
    Quote Originally Posted by BajaProductions View Post
    i thought i would test a tiff output vs a qt output to see if there was any difference. BUT, the TIFF matched the QT. So guess that at least there is conformity in that respect. I'm going to continue on with testing here.
    TIFF output becomes gamma 1.8 at default even in Snow Leopard, so be careful.
    Kaku Ito
    rawesome! Equipments
    RED Epic-M, RED Epic-x, RED ONE MX x2, RED ONE Mysterium, Allstar A-mount, Epic Canon Ti Mount, 1.8' SSD modules, RED PRO Prime Set (18 through 100mm), various Nikon and Zeiss Lenses, 17-55mm RED Pro Zoom, 18-85mm RED Pro Zoom, x2 RED ROCKET, Mobile Rocket, DaVinci Resolve, Cubix, GTX-285, Quadro 4000, few Mac Pros, few MacBook Pros, Sony BVM-D24, Panasonic 65 inch Series 12 plasma, Calman with Klein probe.
    Rawesome! One Stop RAW Visual Production Service
    Feb 2008
    Chiyoda-ku, tokyo
    please post the short r3d.
    Kaku Ito
    Feb 2007
    Quote Originally Posted by Kaku Ito View Post
    The two images i posted were only screen grabs off of my mac from the original QT files beginning at frame one. So all they are is representative of the color de-saturation effect that i am seeing and represent the problem i see when outputting the prores transcodes. It's quite easy to notice that the old RC held saturation and the new RC-X looses saturation after transcoding to prores.
    I'll see about posting two clips tomorrow.
    John Friday
