Click here to go to the first RED TEAM post in this thread.   Thread: Redcine-x Transcodes to Prores 4444 look WASHED OUT
Page 1 of 14 1234511 ... LastLast
Results 1 to 10 of 136
  1. #1 Redcine-x Transcodes to Prores 4444 look WASHED OUT
    Senior Member Johnny Friday's Avatar
    Feb 2007
    La Paz, Baja Ca. Sur, Mexico
    So having difficulty with redcin-x build 221 and trascoding to prores 4444.
    I'm using MacPro, redcine-x build 221, redrocket card that is running from HD-SDI dual link out into an AJA Hi5-3G that converts HD-SDI to HDMi and that is connected to my HP Dreamcolor monitor.
    The monitor is set to REC 709 that has a gamma of 2.4 (not 2.2)--I suppose this is normal for REC 709 ? I have many options with the HP Dreamcolor for colorspace settings such as:
    *Full; AdobeRGB, Rec.601, and a few others, but REC.709 seems appropriate.
    PROBLEM:
    everything goes nice while using redcine-x v221 and image looks great on my HP dreamcolor. My other monitor is a Dell u2410 that has the viewer and other workspace on it. It does not match perfect the dreamcolor, but it's not terrible. So, when making color corrections everything is good, then i go to transcode to Prores 4444 and my settings are:
    Motion:
    frame per second: 29.97 (it was shot at that speed)
    Gamma Correction: None
    Depth: millions of collors +
    **When i finally get the file baked as a .mov and play it, the image/movie is very unsaturated and has a WASHED OUT look to it. It's as if all the color I put into it with the first pass of color correction was for nothing. It is quite frankly not even a close representation of the image i created.
    *I also had downloaded the latest quicktime component and installed it in the redcine library. So that was done.
    Anyone have an explanation or fix?
    John Friday
    La Paz, B.C.S., Mexico
    www.bajaproductions.com
    EPIC M & 2X for 3d & Deep Epic Underwater Housing
    RED MX with SSD & Underwater Housing
    It sounds like the grade is not applying to the clip you are wanting to render.
    To test this I set up several output settings.
    One of each for prores 4444, uncompressed hd, DVCPROHD, AVID DNXHD, etc. to see how all the different codecs would render.
    Create a 5 frame clip in the timeline and then render out each output setting and compare the QT files. You will see that QT handles the gamma for each differently.
    As a workaround to get the gamma to match you might have to create presets for each codec that will yield a correct gamma in the rendered file.
    This is a problem in quicktime in that it will randomly assign GAMMA to a specific codec even if RCX is asking it to render a specific gamma, QT will choose it's own.
    I have found that PRORES is the most accurate compared to the INternal monitoring in RC-X.
    It's pretty hard to get all the GAMMA settings right when there are so many output variables. You really have to test each one and figure out the "gamma offset". Plus there are many values being plugged into the render data including curves, shadow, exposure and FLUT that will have an impact on what the blacks look like, so it can be tricky to get it right, but you have to test.
    David
    "A revolution is not a bed of roses.
    A revolution is a struggle between the future and the past." – Fidel Castro
  3.   Click here to go to the next RED TEAM post in this thread.
  #3
    Red Team Deanan's Avatar
    Jan 2007
    What application are you playing it back on?
    Feb 2007
    Deanan,
    I'm just playing back the Quicktime files on both Quicktime x and Quicktime pro v.7 And the look is the same on each of those....I've transcoded in the past on older versions of redcine-x and cannot recall images such as these. Just look too bright/overexposed and washed out of color.
    David: I'm trying a variety of outputs now.
    John Friday
    Dear John,
    Do you have the "Use restricted SMPTE range" check box checked in your RC-X Export Preset? If so, try un-checking it. I have found this to produce flatter results in the ProRes files than how the grade appears in RC-X.
    ALSO, when you view your ProRes files, are you viewing them in the QuickTime player or in Final Cut Pro? Try viewing them in Final Cut Pro - sometimes the QuickTime player doesn't look accurate even though the files themselves look great in FCP, Color, etc.
    Best,
    - Jordan
    Jordan Livingston
    Leading a double life...
    IATSE Local 600 ICG DIT
    www.DIGILOID.com
    Independent Filmmaker
    www.JLPMOVIES.com
    Feb 2007
    Quote Originally Posted by David Battistella View Post
    It's pretty hard to get all the GAMMA settings right when there are so many output variables. You really have to test each one and figure out the "gamma offset". Plus there are many values being plugged into the render data including curves, shadow, exposure and FLUT™™ that will have an impact on what the blacks look like, so it can be tricky to get it right, but you have to test.
    David
    David, first off thanks for the assistance. I tried a variety of presets and found that my best results to get the richest colors back out of QT compared to what i was grading in RCX was to choose prores 444 or 422HQ and select Gamma as "NONE" instead of Automatic. That was about my only choice in the presets other than checking "restrict SMPTE" i tried with it checked and unchecked and did not find much difference in the QT prores file that was ouput---or i might say a very slight difference....which lead me to keep it unchecked.
    Quote Originally Posted by Jordan Livingston View Post
    Dear John,
    Best,
    - Jordan
    Jordan, I have only been viewing in the QT file and have not yet checked in FCP. And as you see in my post above, i did uncheck "restrict SMPTE" and results were slightly better.
    RESULTS THUS FAR:
    to re-hash, it seems in my case presetting prores4444 and selecting Gamma as "NONE" gives me a better look. HOWEVER, the QT movie is still not as nice as the RCX image i graded.
    Hardware: Keep in mind, i am viewing RCX image via REDROCKET card output via HD-SDI into AJA Hi5-3G that basically converts 12bit HD-SDI to 10bit HDMI into my HP dreamcolor that is setup with the REC.709 color space. So, in essence i'm viewing the RCX images at 10bit and then when i go to view the QT movie file i created, i then switch my HP monitor to DVI input from my mac tower that is of course only 8bit --AND i am running two monitors at once off the graphics card--NOT SURE IF RUNNING TWO MONITORS MAY ALSO BE A PROBLEM....but result is that the QT images viewed on my same monitor, but at 8bit are less rich than they are viewing on RCX at 10bit. But the difference is not slight....it's quite noticeable. They are less saturated and slightly washed out...not nearly as bad as before when i had Gamma set to "Automatic".
    Could there be another issue in order to get them to match completely? I don't recall having these issues in the past on Redcine v. 20.
    Thanks to all for the assistance.
    Jordan, I'll have a look in FCP within the viewer at the QT movie and add feedback on that as well.....and then again in color.
    John Friday
    Yes,
    I found that switching off automatic was an improvment. It would be good if you could look at the files from FCP in 10-bit via a KON card and you might be pleasantly surprised at the results.
    David
    Feb 2007
    Yes,
    David
    I wish....i know. AH---just thought of what i can do...I dont' have a Kona Card, BUT i do have MXO2 and that connects via HDMI---should work into my Dreamcolor. I'll have to check that as well. I may not get to all of this tonight....I expect tomorrow or a day later, but i think that would get things closer to a firm result one way or the other. But i must say that 8bit vs 10bit kind of sounds out there to see a big difference. You may in fact be right, but I've done quite a bit of color work via 8bit and just don't recall seeing a difference like this when viewing 10 or 12 bit. But now my eye is much more keen on CC work since i am doing it almost every day now.
    John Friday
    Feb 2007
    Viewed QT reders in Color as well as Final Cut Pro with output to my HP Dreamcolor @ 8bit color (not 10bit like my Rocket Card ouputs).
    Looks better, but still slightly less saturated than the RCX look out to 10bit monitoring.
    I'm beginning to think that it really is a question of 8bit monitoring vs 10 bit monitoring. ???
    Next is to try viewing via my matrox MXO2 LE out via hdmi (10bit) to see if image will look as i graded it in RCX and viewing at 10bit on my Dreamcolor.
    John Friday
    Senior Member Kaku Ito's Avatar
    Feb 2008
    Chiyoda-ku, tokyo
    John,
    In REC709, gamma level is not specified. People choose it according to the ambient light surrounding of the room. Safe bet is 2.2 in normally lighted situation, but if you darken the room then higher number like 2.3 or 2.4 is used. For example, for DCI, the gamma level is 2.6.
    In my opinion, Dream Color is over saturated when you use it with Mac.
    Kaku Ito
    rawesome! Equipments
    RED Epic-M, RED Epic-x, RED ONE MX x2, RED ONE Mysterium, Allstar A-mount, Epic Canon Ti Mount, 1.8' SSD modules, RED PRO Prime Set (18 through 100mm), various Nikon and Zeiss Lenses, 17-55mm RED Pro Zoom, 18-85mm RED Pro Zoom, x2 RED ROCKET, Mobile Rocket, DaVinci Resolve, Cubix, GTX-285, Quadro 4000, few Mac Pros, few MacBook Pros, Sony BVM-D24, Panasonic 65 inch Series 12 plasma, Calman with Klein probe.
    Rawesome! One Stop RAW Visual Production Service
