Hi David,
I think the issue is not the possible size of the camera - after all it's a modular system, and many, many folks will be using pretty big rigs based on the Epic for the majority of work, I don't see any reason to insist the camera must always be small, that's just a limitation of it's own. If you want a small camera package, no problem, don't use the modules - that's the beauty of Epic's modular approach! I want a camera that does what I need, and size and weight are rarely major concerns.
The bigger issue for me is workflow, and compatibility. All of these Ki-Pro/Pix-240/etc solutions are workarounds, unfortunately. They won't record off-speed, for a start, and for drama (and often music promos, and even these days more and more documentary and episodical TV, which is where high quality proxies are really, really necessary) many people shoot a pretty large amount of off-speed. They also, currently, won't record full-raster 1080p because it's not what's coming out of the spuds on the Epic. I know that will change, but still...
I'm with you on the lack of excitement about H.264 though - I don't want another format that needs transcoding to play nicely with an NLE, and definitely not one that's too low quality to finish a broadcast show in. I guess Red have done their research here and found a need/desire for it, but I can't see it myself...
For my money, the module you need (and I do think it wants to be a proper Epic Module) is a switchable Pro-Res/DNxHD recorder, recording onto SSD or CF, that will record the frame output by the Epic in 1080p at whatever framerate the camera is recording, with matching TC and Clip Name for conform if desired. Where Alexa is taking chunks out of Red/Epic shows is the ability to go to broadcast very, very quickly with an excellent image. Not as good as one that's had a ton of time spent over it in a grading suite from RAW, no - but pretty bloody close on the kind of post budgets and timescales that broadcast demands. The shows that shoot Alexa are simply never, ever going to migrate to a RAW workflow. They also won't be finishing from H.264 any time soon - so, compete or go find another game. I'd like to compete, personally! Especially given just how great a PR444 image from the Epic could be.
Now I don't know if the above wish-list is possible given the architecture of the Epic, but even if you need to sacrifice the higher framerates (say, above 60fps) to do it, it would be much better than a system which means you need to stick to on-speed shots only.
Just my 0.02, from what I see and hear about the choices people are making and what I'm being asked by Producers, and YMMV, of course...
Dom.
