Thread: Clipfinder. Command G opens Google?
Results 1 to 6 of 6
  1. #1 Clipfinder. Command G opens Google?
    Mar 2008
    know this isn't a prob with CF but hopefully someone can help. When I press cmd g a safari window with google opens up! I can't find where to reset this so I can render in CF with CMD G. crazy hung? Thanks in advance!
    Re #1313
    "Lucky!"
    Moderator Martin Weiss's Avatar
    Mar 2008
    mostly Norway
    Sounds like you've installed an application launcher. Have look at your list of startup items.
    Or have a look in system prefs. under mouse/keyboard to see if smth. is set up for command-G.
    Photographer
    RED AC/DIT
    www.jbalster.com
    Senior Member Alexander Christ's Avatar
    Zurich, Switzerland
    Google Voice and Video plugin for GMail installed? http://www.reduser.net/forum/showthread.php?t=36095
    Alexander Christ | owner manager, DP, digital cinema specialist | OCTAMAS
    RED Rental | Post Production | Production
    2x EPIC-M #434, #446
    2x EPIC-X #231, #236
    1x SCARLET-X #388
    It all started with RED ONE #419, #420
    EPIC & SCARLET & RED ONE Menu Guides
    If you're running Snow Leopard have a look at the system Keyboard preferences, specifically "Services" in the "Keyboard Shortcuts" tab.
    Hans
  6. #6 Command G Solved!
    Mar 2008
    I JUST figured this out. It was Quicksilver. Turned off now.
    Re #1313
    "Lucky!"
