Now up...
http://reduser.net/forum/showthread.php?t=40067&page=2
RCX Build 183
Audio:
Exporting audio channels no longer requires channels with a lower index be preset in the file.
Automatic Audio Sync algorithm improved.
Exporting:
Export option to overwrite or to add "_S###" to the file name.
Avid MXF export has been added to windows.
Black Frames bug fix
Timecode metadata fix
Burn-In text improved
Burn-In Timecode fix
Open Exr added (preliminary)
16bit DPX added (preliminary)
Gui:
Video player improvements
Ability to save and load presets to/from separate files
Reset in/out points added - Option click the in/out point buttons when a clip is in the video player.
Option-clicking a clip's resize handle in the timeline will also reset in/out points.
Detail window green box will now go away when the detail window is closed.
LUA scripting added to windows.
Framing and Framing Presets windows are now a single window.
The Sharpness and Denoise sliders were moved from the Detail Tool to the Image Tool.
The Debayer slider on the Detail Tool was removed.
External audio match information for each clip is now saved in project files.
RED Rocket™™™ Monitor Out:
Timecode added to monitor output. Edge/Abs/Timeline
Color Science:
White balance tweak for Sodium Vapor lights
Windows features not enabled:
Audio playback
openEXR support
